which walboro?
Old Jul 30, 2001 | 02:00 AM
paulzy's Avatar
Default which walboro?
The reular 255lph or the high pressure 255 lph? it's only like a 5 dollar difference...oh yeah, and where can I find a new filter for the fuel pump? The little bag at the end of the pump? Does $107 for a high pressure 255lph pump sound right? Is there a place where they sell it cheaper Than that? Just a FYI, the regular 255lph costs $92...
[Modified by Slow_ass_4dr, 3:01 AM 7/30/2001]
Old Jul 30, 2001 | 07:47 AM
MackSpeed-616's Avatar
Default Re: which walboro? (Slow_ass_4dr)
i am also looking for a good intank fuel pump able to feed about 500crank hp. Only pushing about 45psi of pressure. thx
Old Jul 30, 2001 | 08:36 AM
5 Liter Eater's Avatar
Default Re: which walboro? (TurboR616)
It depends on your setup. If you are using stock injectors with an FMU to get pressures up around the 100 PSI range then definitely get the high pressure model. If you have larger injectors that do not require such high pressures then the low pressure model would be fine. I'm not sure whether either would support 500 HP.
Old Aug 23, 2001 | 07:34 PM
The Punisher's Avatar
I am going to be installing the FMax turbo kit on my 93 Vtec Prelude. I am re-building the bottom end so I can run at least 12 PSI of boost. I too want to upgrade my fuel pump. Please give the site or contact info for the place you found it at this price! Also, in using the MF2 and extra injectors that come with the kit, which pump would be right for my application, the high pressure or regular?
Old Aug 23, 2001 | 08:08 PM
Flamenco-T's Avatar
what are the advantages of walbro versus bosch other than the names ?
I know most DSM'er that I know like the walbro, but most honda's always go for the bosch...
any opinion ?
Old Aug 23, 2001 | 08:23 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: which walboro? (flamenco)
any opinion ?
The reason most DSM's go for the walbro is because they dont have the high fuel pressures that us Hondas with FMU have. If you were to go stand alone you could use the Walbro intank pump on the hondas because you will not have the high fuel pressures.
The Bosch is the only pump that I know of that can handle 100+psi fuel pressure. The walbro can not keep up with the high fuel pressures.
Once I go Hondata Im getting rid of my bosch and getting a walbro intake pump.
art
Old Aug 23, 2001 | 08:26 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: which walboro? (Arturbo)
lol, can you count how many times I used the statement "fuel pressure"?
art
Old Aug 23, 2001 | 08:54 PM
Flamenco-T's Avatar
art
should I wait for you ? LOL
Old Aug 23, 2001 | 08:55 PM
Arturbo's Avatar
Better than steak
25 Year Member
If you want to wait that long....I should be in the next two months.
art
Old Aug 23, 2001 | 09:09 PM
Mikex25's Avatar
New User
where can you get a Bosch in tank fuel pump from I can't find any places that sells them.
Old Aug 23, 2001 | 09:40 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: which walboro? (Mikex25)
Bosch doesnt sell an intake, you have to modify it or get it from http://www.theoldone.com/components/fuelpumps/
art
Old Aug 23, 2001 | 10:31 PM
Mikex25's Avatar
New User
Man that is expensive 279 or soemthing like that, Do you know of any places that sells Walbro in tank fuel pumps? the help is greatly appreciated thanks alot.
Old Aug 23, 2001 | 10:38 PM
93LSivic's Avatar
check where i posted in this thread from the other day.
https://honda-tech.com/zerothread?id=61791
Hope this helps!
Old Aug 23, 2001 | 10:43 PM
JaEz's Avatar
New User
wait wait wait.......i juss ordered my drag kit with a bosch fuel pump, and i also ordered my hondata stage 4.......does that mean i made a mistake on going with the bosch ? or will i be okay ???? thanks
jase
Old Aug 23, 2001 | 11:06 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: which walboro? (JaEz)
You will be ok...
art
Old Aug 23, 2001 | 11:18 PM
JaEz's Avatar
New User
hey art.....why are you gunna switch it out though when you get hondata ?
what difference is it gunna make ?
thanks man,
JaSe
Old Aug 23, 2001 | 11:43 PM
Arturbo's Avatar
Better than steak
25 Year Member
Well, since I wont be running the high fuel pressure that the FMU makes I really wont need the bosch. If I run the walbro intank with no high pressure then I'll be ok. Also, the noise of the Bosch doesnt bother me but I would like to get rid of the buzzing noise.
But I could use the bosch.
art
Old Aug 24, 2001 | 10:26 AM
I did some checking on the difference between the pumps, and get this, there is very little! The High Pressure pump flows at about the rate as the regular, but where the regular seems to fall off at, the HP one keeps the pressure up! So, if your setup tends to lean out on the top end the HP pump would be the way to go. But just my two cents though...
Old Aug 24, 2001 | 12:18 PM
apexii's Avatar
Default Re: which walboro? (gsr*lude)
For my prelude I am using the walboro awd dsm pump, it works nicely in a prelude.
98hx99b18c's Avatar
If you're going to be using an fmu on your setup go with the high pressure pump otherwise stick to the low pressure, Also the walbro intank comes with the new filter.
Old Aug 24, 2001 | 03:13 PM
paulzy's Avatar
Default Re: which walboro? (98hx99b18c)
thanks guys
FlewByU352
Jan 2, 2012 05:41 PM
boosted91REX-SI
Jan 9, 2009 04:52 AM
JDM00SI
Feb 7, 2006 10:39 PM
Braco11
Apr 29, 2003 06:18 AM
Anubyss
Apr 23, 2003 06:54 AM
