Waistegate problem
Old Oct 27, 2001 | 07:16 PM
Alphahelix's Avatar
Default Waistegate problem
If I am running in top gear on the highway and ease into the gas to pass a car without down shifting, my waistegate makes a chattering sound. Any ideas. I thought at first the spring tension might be set wrong but I thought I would ask around first.
Old Oct 27, 2001 | 07:27 PM
LsTurbo91's Avatar
Default Re: Waistegate problem (Alphahelix)
It might just be opening and closing a bit. I've had that before.
Old Oct 28, 2001 | 05:12 AM
Alphahelix's Avatar
Default Re: Waistegate problem (LsTurbo91)
is there a cure for this ?
Old Oct 28, 2001 | 08:36 AM
GSRwBOOST's Avatar
yes.. get on the gas harder and let her open up the whole way
if you have a boost controller it should stay shut until you reach max boost.. thats one solution....
second one is to reroute it into the exhaust so you dont hear it at all....
GSRwBOOST's Avatar
are you sure it's not detonation also?
Old Oct 28, 2001 | 08:55 AM
Alphahelix's Avatar
Default Re: Waistegate problem (GSRwBOOST)
Well, I can stand on the gas in top gear and it will still do it. As far as a boost controller I have a Profec B. I don't think it is detonation, but I cannot say I am 100% sure. The A/F is right on (verified on a Dyno with Gas Analyzer and with the Greddy A/F gauge that is installed). My timing could be off, but under steady state cruise the car runs good and at WOT running through the gears the car runs even better
pjr710
Jan 5, 2009 11:15 PM
Screamer
Apr 22, 2003 05:09 AM
gsr sol
Mar 2, 2003 02:33 PM
B18C-RnVA
Nov 11, 2002 01:32 PM
freeplay
Oct 13, 2002 07:11 PM
