Tunning Boost for Street
Old Apr 21, 2003 | 07:16 AM
Screamer's Avatar
Default Tunning Boost for Street
What would be the prefered a/f ratio when tunning for street use on 94 octane gas??? I want to push as far as I can, but I just want some recommendations before I start doing anything.
Old Apr 21, 2003 | 07:47 AM
1.8T_EG's Avatar
Default Re: Tunning Boost for Street (Screamer)
... i have seen between 11:1 and 12:1 is both reliable and strong... and ~12:5 being a little more aggressive... correct me if i am wrong cuz i'd like to know for sure also... thanks...
Old Apr 21, 2003 | 07:58 AM
Mase's Avatar
Default Re: Tunning Boost for Street (1.8T_EG)
it also depends on the motor, CR, etc.
Old Apr 21, 2003 | 10:16 AM
Screamer's Avatar
Default Re: Tunning Boost for Street (Mase)
My engine is a build b18c with 9.5:1 cr.
Old Apr 21, 2003 | 10:48 AM
PM-Performance's Avatar
we tuned mine for out of boost for like 14.5 or so , for gas mileage, and in boost for like 12.1-12.5 for safety.
i get decent gas mileage if i stay outta boost and make pretty good power seeming that my exuast is cloggin me down a bit
Old Apr 21, 2003 | 11:27 AM
BlueSi2k's Avatar
I would tune for 11.5-12.0 and retard about .75 deg per pound of boost to keep it safe...and around 14.5 out of boost as stated above.
Old Apr 21, 2003 | 11:33 AM
boosted hybrid's Avatar
Default Re: (BlueSi2k)
12.0:1 is plenty to keep it safe, .5 degree per pound of boost is plenty safe. Set up the car close to 12:1 air/fuel and run 1 degree per pound of boost till you get to the dyno. That is basically what I do when i tune on the street.
Old Apr 21, 2003 | 11:39 AM
RAWB's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Screamer &raquo;</TD></TR><TR><TD CLASS="quote">for street use on 94 octane gas</TD></TR></TABLE>
Damn, I hate California gas
Old Apr 21, 2003 | 12:53 PM
Screamer's Avatar
Default Re: Tunning Boost for Street (RAWB)
Ya, we are quite lucky here in Canada with the 94 octane gas.
I hope I can get as close to 425whp (my goal) as it is possible without going with race gas. Is there anyone out there that has hit these numbers or anywhere close???
Old Apr 21, 2003 | 12:55 PM
Brokenvtec was around 400whp on pump gas at 12psi with his set-up. I should be around 450whp on pump gas with my set-up at 15psi. It can be done. If you arent running a 2.0 Liter bore, I doubt its going to happen.
Old Apr 22, 2003 | 05:09 AM
Screamer's Avatar
Default Re: Tunning Boost for Street (boosted hybrid)
What type of turob are you running to hit such high hp levels with such low boost??? What about your friend? I am also guessing he has a 2L block as well?
pjr710
Jan 5, 2009 11:15 PM
aalb1
Nov 15, 2005 02:09 PM
B16Civic93
Jul 13, 2005 02:12 PM
ramz7887
Apr 29, 2003 09:34 AM
1.8T_EG
Oct 25, 2002 02:46 PM
