voltage for iacv?
Old May 10, 2007 | 08:46 PM
the.hamburglar's Avatar
Default voltage for iacv?
does anyone know the voltage the iacv should be getting?
Old May 11, 2007 | 02:26 AM
DaveF's Avatar
Default Re: voltage for iacv? (the.hamburglar)
it should recieve a 12v key on sig from the yel/blk. and on obd1 ecu's the blu/blk runs to pin #a9
Old May 11, 2007 | 12:13 PM
Default Re: voltage for iacv? (dturbocivic)
so having a poor alternator would affect voltage to the iacv? i know its my iacv now, so i just have to figure out why its doing this. thanks
Old May 11, 2007 | 06:19 PM
DaveF's Avatar
check for a bad connection @ the dead end plug on the left side of the engine bay
Old May 11, 2007 | 08:21 PM
dead end plug...hmmm..can you be more specific? i still have the idle surge. i got a new map sensor, tried out a friends ecu and chip. it seems to come and go now. also it seems to only surge 3 times and then steady off. any ideas?
Old May 12, 2007 | 07:42 AM
DaveF's Avatar
possible vacum leak around the throttle body, make sure your gasket covers the entire outer perimeter, or you are sure to have a problem.
maybe the FITV is a bit loose if you happen to have that style TB.
Old May 12, 2007 | 08:22 AM
yep im checking for vacuum leaks today with soap and water. what was that plug you were talking about? what i dont understand is why it only happens sometimes....ususally after i have taken it over 5000rpm and or once its warmed up. i never get it on a cold start and for at least the first 10 minutes of driving.
BJA86
27
Apr 8, 2008 03:57 PM
19992civichatch
Mar 15, 2007 07:33 PM
Linh.
Jul 3, 2006 09:08 PM
homeskillet
Jan 4, 2005 11:05 AM
