boost questions....
Old May 11, 2007 | 09:45 PM
fast92hatch's Avatar
Default boost questions....
i need to have an i dea about how much psi to run on my built b18c. its all forged with 8.5:1 compresion ross pistons and darton sleeves. i was thinkin are 30psi. but i want to be sure before i try it. i have a lot of monet in the motor any dont want to destroy it or blow a head gasket.
Old May 11, 2007 | 10:23 PM
SD_Lurker's Avatar
HT White Ops
Default Re: boost questions.... (fast92hatch)
What rods do you have? Darton sleeves will handle 30PSI without a hitch. If your motor is built properly I don't see any reason that you couldn't boost 30PSI. Your using head studs, correct? If so I wouldn't worry about blowing a head gasket. Also, what kind of numbers are you looking to get? 30PSI is quite a bit so I am assuming your looking to get some serious numbers.
Old May 12, 2007 | 08:26 AM
1995Civic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fast92hatch &raquo;</TD></TR><TR><TD CLASS="quote">i have a lot of monet in the motor any dont want to destroy it or blow a head gasket.</TD></TR></TABLE>
Blowing a HG would be the VERY least of your problems that could occur.
bowtieboy911
12
Apr 4, 2011 03:36 AM
AngelTeg
Nov 30, 2005 08:20 AM
jaxx4k
Apr 2, 2005 05:11 AM
Nikolai
Jul 17, 2002 09:39 AM
InfamousRS
Dec 15, 2001 06:02 PM
