VAFC HACK Question
Old May 30, 2003 | 04:23 PM
EggEX2000's Avatar
Default VAFC HACK Question
Do you have to have DSM 450cc Injectors or can you do the same exact thing with RC 440cc's???
~Mike
Old May 30, 2003 | 04:27 PM
dirtySOHC's's Avatar
Default Re: VAFC HACK Question (EggEX2000)
yes
Old May 30, 2003 | 07:25 PM
KC GSR's Avatar
you can do the same thing with 440s
Old May 31, 2003 | 02:31 PM
scttydb411's Avatar
you can do the same thing with any larger injector. it just depends on how much you need to correct your map voltage. the size of the injector is based on how much fuel you need based on how much correction you have to your map signal and how much psi running. more psi, more correction, more fuel, larger injectors, etc.
Old Jun 1, 2003 | 12:38 AM
Default Re: VAFC HACK Question (scttydb411)
you can only go so far with the hack. when you are going with anything higher than 450cc's you are lowering your ability to trim down the fuel. i remember reading someone running something around 500cc's and his vafc settings were between -48 to -45, now if you ask me there is not so much to play with when you are already that low.
Old Jun 1, 2003 | 07:16 AM
scttydb411's Avatar
Default Re: VAFC HACK Question (dirtySOHC's)
what i mean by using larger injectors is 310-450. larger than 450 he would need to be able to consume the fuel with say a much higher boost. higher boost means he would need that much more fuel and then also need to trim back closer to -50, but yes there is a limit to how much the hack can be used unless changing the map sensor.
Old Jun 1, 2003 | 12:47 PM
swlabhot's Avatar
Default Re: VAFC HACK Question (b3435)
Yes I run 500cc untuned and the lowest trim is now around 48% so I still have about 2% to play with. 550cc can be done but you will run very rich as you cannot trim any more than 50% on the AFC. Its not so much the injector size thats the question, its the level of fuel trim that you have to play with by any form of fuel trim/piggy back device that enables you to provide the correct fueling.
Old Jun 1, 2003 | 01:16 PM
Default Re: VAFC HACK Question (swlabhot)
there i was talking about that guy running 500's
89 CRX SI
Feb 3, 2004 06:01 PM
0 0 0
Jan 15, 2004 07:48 PM
1.8T_EG
Dec 9, 2003 09:11 PM
NeXtLeVeL_TyPe_R
Jul 26, 2003 11:58 PM
Turbohatch
Jul 31, 2001 11:25 AM
