afc hack and MAP sensor question
Old Apr 13, 2004 | 02:21 PM
igo4bmx's Avatar
Default afc hack and MAP sensor question
I understand that timing will change with the afc hack when getting into boost, but is there a way to lessen the voltage output by the afc toward the MAP sensor?
just an idea i thought of
Old Apr 13, 2004 | 04:13 PM
USDM 4G VTEC's Avatar
Default Re: afc hack and MAP sensor question (igo4bmx)
the MAP sensor has 5V all the time
based on pressure readings it will vary from 0-5 Volts signal to the ecu
the VAFC overides the signal going to the ecu to control the fuel amount
theres no need to alter the signal to the MAP sensor since it will compeltely trow off the readings and purpose of the MAP parameter readings
MatthewMenze
Engine Management and Tuning
May 1, 2014 01:24 PM
_Justus
Apr 18, 2013 02:08 PM
boostedcivicsir
Oct 26, 2008 02:14 PM
aldong
Oct 8, 2006 06:15 PM
4dooritr
Feb 24, 2006 02:59 PM
