vacuum source
Old Mar 1, 2009 | 07:12 AM
turbo sol's Avatar
Default vacuum source
i am finishing up my build and need to run all my vacuum lines for my boost components.
I have a vacuum block installed, but instead of splicing into the brake booster line, I used an extra port on the S2 manifold. (this is still ok right?)
is it ok to hook my BOV, wastegate (through a manual boost controller), boost gauge and other decives to this vacuum manifold, even though this vacuum/boost source is after the throttle body plate?
some of the diagrams I have seen have the wastegate hooked to a fitting on the compressor housing of the turbo, my turbo doesn't have one of those.
Old Mar 1, 2009 | 07:22 AM
dart2.2's Avatar
Default Re: vacuum source
tial recomends hooking your wastegate up pre-throttle body so no vac is put on the diaphragm and only see's boost. assuming you have a tial.everything else is ok.
Old Mar 1, 2009 | 07:38 AM
turbo sol's Avatar
i do have a tial. (38mm)
so i guess the next step is removing the compressor housing and tapping in a fitting for the wastegate?
is there a special type of fitting (size?) that I should look for?
Old Mar 1, 2009 | 08:23 AM
turbo sol's Avatar
i am trying to find something I saw,
it was a nipple that was placed in the silicone adapter where the housing connects to the intercooler piping. what might be a good fix.
anyone know what I am talking about?
Old Mar 1, 2009 | 08:30 AM
grndcont's Avatar
you can run it just like you have it now. i dont have the fitting in my compressor outlet either, runs fine. just hook up all your **** to the vac mani.
Old Mar 1, 2009 | 08:47 AM
turbo sol's Avatar
http://www.034motorsport.com/product...roducts_id=358
this is what I am talking about.
if it doesn't really matter then cool, but if its safer this way I'll pick one up and install it.
tundra2000
Sep 26, 2010 06:42 AM
draconx
Mar 15, 2006 06:03 AM
asianspeed
Mar 1, 2006 09:34 PM
B16CRXT
Apr 24, 2005 07:50 PM
It's*BOLO!!
Apr 8, 2003 12:09 PM
