BOV and wastegate hoses
Old Apr 7, 2003 | 07:13 PM
It's*BOLO!!'s Avatar
Guess whos bizzack
Default BOV and wastegate hoses
can they go to any vacuum source, and to hook up the manual boost controller, it goes from the wastegate, to the controller, to a vacuum source am i right?
Old Apr 7, 2003 | 07:47 PM
TeStUdO's Avatar
Default Re: BOV and wastegate hoses (Y49CRXSIZC)
BOv to any vac source. wastegate side port to vacuum top port to boost controller
Old Apr 8, 2003 | 06:51 AM
Guess whos bizzack
Default Re: BOV and wastegate hoses (00si5)
i only see one thing on the top on my wastegate(14b), no side?
Old Apr 8, 2003 | 11:01 AM
Guess whos bizzack
well i received my manual boost controller today, it has 2 ports for hoses, one it says to run to the wastegate, the other it says to run to a boost source, does this mean any vacuum source in my car?
Old Apr 8, 2003 | 11:25 AM
fsp31's Avatar
You can use "any vacuum source", but I would *highly* suggest routing it on it's own line (with nothing T'd into it) straight to the intake manifold. There are 2 reasons for this:
1) It promotes faster wastegate response and can reduce/elminate boost spikes.
2) Insurance! What if whatever you have T'd with the wastegate suddenly breaks, causing the wastegate to see 3 psi even though there's 12 psi in the intake manifold? If 12 psi is the limit of your motor, then kiss that engine goodbye... It's just safer to have the wastegate isolated since it's the most important safety feature in the entire system IMO.
Old Apr 8, 2003 | 12:09 PM
Guess whos bizzack
Default Re: BOV and wastegate hoses (fsp31)
ok i understand, i will run it alone, thanks for the good info
98integralsB18
Jul 25, 2009 07:29 AM
.David
Jun 4, 2004 10:50 PM
BoOsTiN Dc2
Apr 26, 2004 07:24 AM
pissedoffsol
Oct 19, 2003 09:37 AM
luckypon7
Jul 1, 2003 06:39 PM
