Vacuum Question
Old May 25, 2006 | 05:33 AM
Neeko's Avatar
Default Vacuum Question
I've done a lot of searching and can't seem to find a definitive answer as to whether or not it can be used as a vacuum source.
I'm looking to t a vacuum line on my 97 integra for the BOV and I'm wondering whether the hose coming off of the Intake Manifold for the EVAP Purge control solenoid valve (going to the evap canister) would be a good source?
I plan on using the FPR for the boost guage, but need a source close by for the BOV. I'd prefer not using the brake booster since it's all the way on the other side of the engine bay.
Thanks in advance.
Nick
Old May 25, 2006 | 12:02 PM
Neeko's Avatar
Default Re: Vacuum Question (Neeko)
bump....
anyone???? HELP!!!
EDIT: Pics might help a little. The hose with the red arrow is the one I'm wondering whether I can tap for my BOV.
thanks
Modified by Neeko at 5:19 PM 5/25/2006
Old May 25, 2006 | 02:59 PM
second edition's Avatar
spend the $35 on a ge vacume mani...i did and it cleans things up real nice....otherwise, you could tee both off the fpr
Old May 25, 2006 | 03:01 PM
sleeprhatch's Avatar
no don't tap in to that hose. Tap into the next vacuum hose to the right of that hose.
Old May 25, 2006 | 03:18 PM
adictionbass's Avatar
Default Re: Vacuum Question (sleeprhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleeprhatch &raquo;</TD></TR><TR><TD CLASS="quote">no don't tap in to that hose. Tap into the next vacuum hose to the right of that hose. </TD></TR></TABLE>
Old May 25, 2006 | 03:21 PM
Neeko's Avatar
it's ok to go into the PCV vacuum hose? (that's the next one over to the right).
Thanks again...
Modified by Neeko at 9:19 PM 5/25/2006
Old May 25, 2006 | 03:42 PM
coneheadsracing's Avatar
yes use that hose, actually run a new hose right off that nipple from the manifold, and make a catch can for that hose.
Old May 25, 2006 | 08:44 PM
postman's Avatar
Default Re: Vacuum Question (second edition)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by second edition &raquo;</TD></TR><TR><TD CLASS="quote">spend the $35 on a ge vacume mani...i did and it cleans things up real nice....otherwise, you could tee both off the fpr</TD></TR></TABLE>
its worth it
Old May 25, 2006 | 10:16 PM
Dartanian's Avatar
Default Re: Vacuum Question (postman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by postman &raquo;</TD></TR><TR><TD CLASS="quote">
its worth it</TD></TR></TABLE>
I agree. It cleans things up a lot and it uses a better vacuum source, so you will get better wastegate and bov response.
v.i.gsr
Jul 13, 2011 04:09 PM
ericstambaugh07
Apr 8, 2007 10:54 PM
thruvines87
Dec 5, 2004 09:08 PM
redhatchb18
Oct 7, 2003 06:00 PM
MikeMAN
Feb 6, 2003 07:36 PM
