Vacuum lines
Old Aug 5, 2006 | 08:52 PM
dcdcdc's Avatar
Default Vacuum lines
I need to know if this is a correct setup. The turbo vaccum source is the outlet of the turbo which i THINK produces a vacuum source(going into towards the intercooler)(theres a little nipple coming off the outlet adapter or the turbo. Im pretty sure the top set up is good but the bottom one???
Old Aug 5, 2006 | 09:03 PM
20yrsToMidnight's Avatar
Default Re: Vacuum lines (dcdcdc)
I cant see a difference between the two.. in theory this set up would work.. but it gets really hot down there so i would run everything from a few different vac sources on the IM. but its your call
Old Aug 6, 2006 | 10:11 AM
a1320addict's Avatar
Default Re: Vacuum lines (20yrsToMidnight)
Get a vacuum manifold from either Fast-Turbo or Golden Eagle and call it a day.
Old Aug 6, 2006 | 11:33 AM
Default Re: Vacuum lines (a1320addict)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by a1320addict &raquo;</TD></TR><TR><TD CLASS="quote">Get a vacuum manifold from either Fast-Turbo or Golden Eagle and call it a day.</TD></TR></TABLE>
That would be the best way
Old Aug 6, 2006 | 12:33 PM
dcdcdc's Avatar
i would rather not spend money on a vacuum manifold. i rather just use T fittings and such.
whats another vacuum source i can use besides the one that goes behind the manifold like the one in the picture. i dont know much about vacuum sources. i know about the booster one but what about others.
Old Aug 6, 2006 | 12:36 PM
dcdcdc's Avatar
on another note, what about BOV. theres a bolt on it, whats the difference between tightening it and loosening it.
Old Aug 6, 2006 | 04:27 PM
I didn't say it because it's the most cost effective way.
If you are not careful of what you are t-ing into, you may not draw enough vacuum for whatever needs the vacuum source.
Old Aug 6, 2006 | 04:38 PM
Adam.C's Avatar
common a vac mani cost what like $40 tops, its worth it
Old Aug 6, 2006 | 05:09 PM
dpetro1's Avatar
Default Re: Vacuum lines (orangerex04)
the compressor housing is a boost source only. vaccum sources are located after the throttle body. boost gauge and bov will need to see both boost and vacuum. wastegate can see boost only, not sure bout the fmu. you shouldnt use an fmu anyways. you can tee off a few things if you dont wanna get a vacuum mani. fpr and brake booster are good choices.
Old Aug 6, 2006 | 05:19 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: Vacuum lines (dpetro1)
yea, the blow off valve is tee'd into the wrong place. and you cant have that many tees. you wont get engouh vacuum to everything.
also, you cant have a vaccum source hooked up to the wastegate AND a source from the turbo....
just buy a vacuum manifold. dont halfass ****
Old Aug 6, 2006 | 05:28 PM
sc4dr's Avatar
Default Re: Vacuum lines (wantboost)
Fast-turbo is selling them for $25.00 shipped
Old Aug 7, 2006 | 12:54 AM
dcdcdc's Avatar
Default Re: Vacuum lines (sc4dr)
hey thanks guys for the input. im getting rid of the fmu after i get it tuned soon. as for the turbo source, i knew it was a bad idea but just thought it would work. im probably gonna just use the source behind the manifold and the fpr one.
can someone answer my question about bov's. its a hks ssqv, diffference between tightening the nut and loosening it.
Old Aug 7, 2006 | 08:35 AM
TypeSLO's Avatar
it's related to the spring rate of the bov. if you tighten it, it requires more pressure to open the bov. if you loosen it, it requires less.
Old Aug 7, 2006 | 12:22 PM
bch5428's Avatar
autozone has plastic little "manifolds" with 2-5 nipples on em. they only cost a few bucks.
Old Aug 8, 2006 | 09:23 AM
dcdcdc's Avatar
Default Re: (bch5428)
that sounds like a good idea, i will definitely check out autozone.
Old Aug 8, 2006 | 11:38 AM
yee SERIOUS's Avatar
i don't think it's really good to have the bov and wg sharing a vac source. i did it before and it was ok, but doesn't respond as well.
DC2TYPER90
Jan 10, 2012 07:41 PM
PhatBoy5015
Dec 15, 2005 02:18 PM
tub_sephiroth
Sep 17, 2004 10:29 PM
JDubya
Apr 12, 2004 07:48 AM
love2xlr8integra
Mar 24, 2004 08:37 AM
