Vacuum line sizing and routing
Old Mar 12, 2013 | 07:42 AM
Smashback's Avatar
Default Vacuum line sizing and routing
Been a while since I've done this and I know it's probably been covered but just want to be sure when ordering parts to reduce snags during install.
2003 RSX-S, running an RBC with Karcepts TB adapter (has two 1/8" NPT ports) Precision 5858, Tial Q and Tial MV-R.
Looking at using the push-lock type fittings and poly tubing for vacuum lines. Is 4mm vacuum line ok for everythin - I seem to remember using 4mm on the BOV and 6mm on the WG/BC way back when on my B18? Looks like the Tials use 10x1.0mm but people say the 1/8 NPT fittings thread in fine. Turbo isn't here yet so I don't know what size the compressor outlet port is, if it has one?
Routing, no tees:
RBC Adapter port 1 -> Boost solenoid -> Top WG
Turbo Compressor outlet -> Bottom WG
RBC Adapter port 2 -> BOV
Any info is greatly appreciated!
Old Mar 12, 2013 | 07:50 AM
Muckman's Avatar
Moderator in Chief
Default Re: Vacuum line sizing and routing
Tial recommends 6mm ID min so 1/4" line.
I use 1/4" hose for everything to make it simple and consistent.
Old Mar 12, 2013 | 07:52 AM
Smashback's Avatar
Easy enough, I like simple myself thanks!
Old Mar 12, 2013 | 11:01 AM
dicxonjim's Avatar
Where did u buy the push lock fittings at?
Old Mar 12, 2013 | 11:53 AM
Smashback's Avatar
I haven't bought them yet but Vibrant makes some. Verocious Motorsports for one has them.
Old Mar 12, 2013 | 02:31 PM
wantboost's Avatar
Who is Mr Robot?
You can get them cheap at any supply store like Grainger or harbor freight. The ones vibrant sells are identical but lower cost
You can also get them in bulk on eBay cheap.
I like to use hard line wherever possible and use braided line when things go from engine to chassis. I plan on using hard lines for the bulk of my plumbing, both fluid and air, where appropriate. I'll then adapt to a braided line for things like the blow off valve. Having hard lines (like poly or aluminum, etc) that have mounting support along their routing insure nothing will leak or rub through.
b18psi
Aug 20, 2018 06:05 AM
crv-techu
Feb 20, 2008 04:43 PM
aryiman98civic
Feb 22, 2007 10:13 AM
sykotic
Dec 4, 2004 09:49 AM
anguish
Jun 7, 2004 06:54 PM
