Hondata Base maps Please Help!
Old Feb 3, 2004 | 08:32 AM
CivicGSR225's Avatar
Default Hondata Base maps Please Help!
I am planning on purchasing a Hondata fuel management with boost from wiredspeedlab.com with their preset base maps. I am only going to run 7psi with stock internals with a Drag Gen 3 turbo kit. Will wiredspeedlab.com's pre programmed base maps be enough for safe reliable street use, or will I need professional tuning right away?
Old Feb 3, 2004 | 08:45 AM
HXMan's Avatar
Default Re: Hondata Base maps Please Help! (CivicGSR225)
I boosted some on my base map.....
...I would plan on getting it tuned sooner rather then later though.
Old Feb 3, 2004 | 09:55 AM
tslag's Avatar
I boosted for about 3 months on a base map. It sucked. I got horrible results and bad gas mileage. I gained 40 whp by having it tuned. I would get it tuned. The base map should make the tunning faster and easier though.
Old Feb 3, 2004 | 03:20 PM
Default Re: Hondata Base maps Please Help! (tslag)
Thanks guys, I appreciate it alot. Well i guess I will have to set aside some extra cash for tuning after the install.
Old Feb 3, 2004 | 03:38 PM
ebp 99 si's Avatar
it should work for a while as long as you don't run the hell out of it
after u get it imo...i would start saving for professional tuning
Old Feb 3, 2004 | 04:08 PM
Silverbeast's Avatar
Just remember base maps are just that a base. It will get you to a tuner or dyno...which is what they are designed to do.
Old Feb 3, 2004 | 05:36 PM
B17aTrbo's Avatar
New User
Default Re: (Silverbeast)
I got my hondata from importparts...along with 880's and 255lph pump...will it have a base map in it that will get me to the shop at which it will be tuned (about 50 miles away)? Or will I have to use the hack and swap everything out when I get there?
Old Feb 3, 2004 | 05:49 PM
Default Re: (B17aTrbo)
Might want to ask Ben on that one. I'm not sure if he made a base tune for you on those injectors...
Old Feb 3, 2004 | 05:52 PM
B17aTrbo's Avatar
New User
I'll have to do that I guess...it isn't the norm for them to put a base map in it?
Old Feb 3, 2004 | 06:01 PM
vtec.dc2's Avatar
don't rush thins like this, or it could end up costing a whole lot more in very short run.. wait until you get it properly tuned..
Old Feb 3, 2004 | 06:06 PM
If they are tuners and not just resellers then yes most will configure some sort of basemap based on your setup.
Ben is a good guy, I'm sure a simple PM to him will anwser your questions about the map.
bcp0715
Acura TSX
Apr 13, 2013 05:14 AM
ITR9788
Jun 9, 2004 02:14 PM
Snafu-Si
Mar 10, 2003 01:05 PM
PrecisionH23a
Sep 3, 2002 09:11 PM
1.8T_EG
Aug 30, 2002 07:36 AM
