Head Gasket??
Old Jun 22, 2008 | 06:32 PM
Honda_Tech01's Avatar
Default Head Gasket??
I'm in the procces of having my motor built.. The piston I chose was a srp 9.5:1 cr. My question is now that i bored the cylinder walls which head gasket should be used. I wanted to use a cometic hg with arp's but cometic does not make a 81.25, they only make 81 and 81.5. should i just use stock bore size.. Thanks
Old Jun 22, 2008 | 09:23 PM
inspyral's Avatar
You can actually just use an OEM gasket(recommended) with a standard .25mm overbore. In fact, I'm running a stock bore gasket with a 81.5mm bore with no problems.
Old Jun 22, 2008 | 09:41 PM
blinx9900's Avatar
Default Re: (inspyral)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by inspyral &raquo;</TD></TR><TR><TD CLASS="quote">You can actually just use an OEM gasket(recommended) with a standard .25mm overbore. In fact, I'm running a stock bore gasket with a 81.5mm bore with no problems.</TD></TR></TABLE>
correct, you can always go + or - .5 the stock HG is actually 81.25 last time i measured one...
Old Jun 23, 2008 | 08:42 AM
Default Re: (blinx9900)
Thanks guys i will be using a 81mm cometic then. thanks
f1 vtec
Jul 15, 2020 02:47 PM
timm099
Jan 15, 2007 08:52 AM
hondaapi
Oct 20, 2004 09:42 PM
turboex
Feb 28, 2004 04:39 PM
d mafia
Nov 9, 2001 02:27 PM
