UPGRADE- new turbo setup inside-shootin for 10s
I decided to upgrade to...
bigger turbo(Master Power 62-1."P" Trim. A/R .84. T3)
top mount manifold(John Pham built)
50mm BOV(Tial)
shooting for 450whp same boost level, made 387whp on turbonetics t3/t4 57trim
car went 11.2 with 16psi on old turbo, shooting for 10's on same boost level with this turbo
flat black aluminum charge pipes
jet coat hot side
polish black cold side
50mm BOV(Tial)
jet coat hot side
Re: UPGRADE- new turbo setup inside-shootin for 10s
That turbo looks sick man!! Nice setup too!!
Good luck gettin in the 10s shouldnt be a problem with that turbo.
Would you mind giving it up to us what suspension, trans and other mods you have on this car? Tires/rims, I'm just curious because of your times, they're lookin pretty good man. Good luck on getting into the 10s!
nex coilovers with skunk2 drag springs
gsr oem open diff tranny
lensos with MT 24.5x8x13 slicks
gutted interior with cage
had a ebay twisted ram manifold before
Why do you want to run the same boost? It doesn't make much sense. A bigger turbo at the same boost will flow way more air. Putting on a bigger turbo that is not in the sweet spot compromises your daily drivability. You could have had as much luck on the smaller setup by turning up the boost and you would have faster spool.
im not after daily drivability, this is not my daily driver. this turbo should make the power i want at the higher rpm's, 6k-9k is where i need the power, plus i wanna hit 10's at under 20psi. should be achieveable with this turbo since i went 11.2 with 16psi on 57 trim.
b18c1wes
01-05-2005 01:48 AM
