Uberdata help with a GSR
Old Nov 15, 2003 | 01:11 PM
  #26
AROD's Avatar
the distributer in a stock ls is set to 16 degrees advance.
now the map says at this point -6 degrees this will me retarded.
so is the real ingnition setting , set at 20 - 6 = 14 degrees total advance for the ignition block?
Old Nov 15, 2003 | 01:44 PM
  #27
falcongsr's Avatar
What is this crap?
Default Re: (non-vtecAl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by non-vtecAl &raquo;</TD></TR><TR><TD CLASS="quote">the distributer in a stock ls is set to 16 degrees advance.
no. your ignition will fire at 6 degrees after top dead center. thats what -6 means.
at idle your map should read around 16 degrees which is what the distributor should also be set to.
Old Nov 15, 2003 | 01:46 PM
  #28
falcongsr's Avatar
What is this crap?
Default Re: Uberdata help with a GSR (falconGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by falconGSR &raquo;</TD></TR><TR><TD CLASS="quote">
umm..hmm.. well.. on page 2 of that story they talk about listening to the knock sensor directly to hear knock - i am about to go try this! i have an audio preamp circuit and a fm modulator so i shouuld be able to pipe me knock sensor over my stereo :-p
i just need to know which wire the knock sensor signal is on in an obd1 P72 GSR plug. i'll have to crossreference it from my obd2 helms. hmm...excited i am..
well i just installed an audio amp in my car and hooked it up to what i *think* was the knock sensor wire, which was red with a blue stripe.
no idea if that was the right one. i do hear lots of stuff most of it sounds RPM dependant and the engine gets noticably louder in VTEC....my map is conservative so i dont think i even heard detonation. i should go tap on the block somehow and listen in the headphones to make sure the thing is working and i hooked it up right...
Old Nov 15, 2003 | 06:41 PM
  #29
Joseph Davis's Avatar
Pin D3, red with either green or blue stripe.
That's a pretty interesting concept... to properly utilize KS input in electronics, you require a certain amount of signal processing to identify the frequencies you want to monitor. I never thought to see if the KS output was something that could be analyzed by the human ear.
Not bad, stunna.
Old Nov 16, 2003 | 12:01 AM
  #30
falcongsr's Avatar
What is this crap?
Default Re: Uberdata help with a GSR (J. Davis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J. Davis &raquo;</TD></TR><TR><TD CLASS="quote">Pin D3, red with either green or blue stripe.
yeah but i have obd2.5 or whatever. so the connector isnt in the helms...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">
Not bad, stunna.</TD></TR></TABLE>
yessir, the human brain is a good audio signal processor with its massively parallel but simple architecture. ****, i sound sober!
Old Nov 16, 2003 | 12:16 AM
  #31
Mr. Softee's Avatar
lol.. you are almost as crazy as j davis / me.
Old Nov 16, 2003 | 05:58 AM
  #32
C3 then, I lack the wiring color in my notebook for OBD2B. I guess I could look at these injector plugs here on the floor, but I am much too slack for that kind of activity. :&gt;
Old Nov 16, 2003 | 09:46 AM
  #33
falcongsr's Avatar
What is this crap?
C3 then, I lack the wiring color in my notebook for OBD2B. I guess I could look at these injector plugs here on the floor, but I am much too slack for that kind of activity. :&gt;</TD></TR></TABLE>
C3 sounds correct. i am confident it is. so i am hearing the knock sensor. one of the links said knock sensors are resonating around 2-12khz which just happens to be the upper range of hearing for the average person.
honestly i would prefer to monitor this on a DSO (digital oscilloscope) so i could really characterize it better. with this info, i think the most comprehensive solution would be using a TI DSP board and develop an adaptive algorithm for detonation detection. it would be a helluva project and overkill but it would be the best damn knock detector on the planet (with the right programmer).
Old Nov 16, 2003 | 09:51 AM
  #34
Mr. Softee's Avatar
you could probably use an i/o board and to input the KS signal and RPM signal into a computer- or through the joystick port. just need someone to write code to interpret it or maybe use that basic dataq software
Old Nov 16, 2003 | 03:48 PM
  #35
riddickone's Avatar
THanks for all the help guys
Old Nov 16, 2003 | 04:14 PM
  #36
Default Re: Uberdata help with a GSR (riddickone)
Why not just dump the 66K processor on the existing Honduh KS boards and reverse engineer it?
Saves a lot of R+D time, and I'm sure there isn't very much code involved - the extra MCU was just used to keep from overburdening the central MCU.
Old Nov 19, 2003 | 07:19 AM
  #37
blundar's Avatar
maybe cause the honda knock boards suck *** for detonation detection in the first place? If reverse engineering was going to take place, I'd at least want to target a device that works better. Honda knock boards are designed for LOW END KNOCK. I.E. bad gas in a high comp motor. They do not work well for the high-RPM boost induced timing too far advanced knock that is universally hard to detect. This seems like my next project. My ex-roomie worked for TI's DSP group for his co-op and I'm sure I could get enough info out of him to get a good start...
Old Nov 19, 2003 | 12:32 PM
  #38
White Smoke's Avatar
i my honda
Global Mod
Default Re: (blundar)
I am pleased with my J&S works Great! I also use the output and datalog with my inovative WB
StreetEG
Feb 17, 2006 08:13 PM
RAW323
Aug 24, 2005 03:34 PM
tuner_3
Feb 10, 2005 11:28 PM
wshondaman
Dec 21, 2004 04:27 PM
