type of GAS to use at the track
Old Apr 18, 2002 | 06:49 PM
98civicEX's Avatar
Default type of GAS to use at the track
here's my set-up
d16y8
TD04 12-14psi
stock internals
440cc's
255lph fuel pump
what kind of gas can i use at the track? they sell 110 octane, but i fear that it's too high....last time i went i used 93 octane w/ that nos octane booster of 7-8points
Old Apr 18, 2002 | 06:56 PM
93LSivic's Avatar
Default Re: type of GAS to use at the track (98civicEX)
Whatever you do use unleaded gas. Dont use the leaded stuff, it will harm your o2 and cat.
I will most likely be running 105 unleaded.
[Modified by 93LSivic, 10:57 PM 4/18/2002]
Old Apr 18, 2002 | 07:08 PM
redline's Avatar
Default Re: type of GAS to use at the track (93LSivic)
vp103 unleaded
Old Apr 18, 2002 | 11:52 PM
sparkz's Avatar
Default Re: type of GAS to use at the track (redline)
Use anything unleaded. You can run C-12 from VP should be around $5-6 a gallon.
Old Apr 19, 2002 | 04:38 AM
98civicEX's Avatar
Default Re: type of GAS to use at the track (sparkz)
great, now where can i get some from?
Old Apr 19, 2002 | 06:51 AM
zojirushi's Avatar
most of the time, the track has that type of gas.
Old Apr 19, 2002 | 06:56 AM
VTC_CiViC's Avatar
Default Re: type of GAS to use at the track (zojirushi)
Last event at Moroso, I just ran some leaded C10 (about 2 gallons) for my 12psi passes, worked like a charm
Old Apr 19, 2002 | 08:12 AM
hybrid901's Avatar
Default Re: type of GAS to use at the track (VTC_CiViC)
How long does it take for leaded gas to tear up the O2 sensor? Say if you mix in a gallon to 2 gallons of 93? Does it tear up anything besides O2 and the cat?
Old Apr 19, 2002 | 08:57 AM
Evil DOHC's Avatar
Default Re: type of GAS to use at the track (hybrid901)
The stock cat gets clogged automatically after 100+ octane. You car run 100 but after that, you better get a test pipe, etc.
EVIL
92 civic VX B18c
Dec 4, 2004 05:46 PM
CRAZYLEGED
Sep 30, 2002 12:43 AM
havok hybrid
Sep 29, 2002 12:05 AM
bracket 4 life
May 27, 2002 11:25 PM
comptechgsr
Nov 1, 2001 03:06 PM
