RACE GAS... 126 octane... is it ok
I have a stock d motor with a turbo on 6psi.. what will i have to do to run 126 octane fuel.... PLEASE>.. fast about to race...
Re: RACE GAS... 126 octane... is it ok (havok hybrid)
wow im goin to use 104 when i goto the track..
how is 100 plus octane fuel made..
i know 87,89,93 and made by adding octanes and septanes or something. the more septanes the lower the grade. septanes combust more easily. so how do they make more than 100% octane?? the y must add something that is better than octane? anyone know
Re: RACE GAS... 126 octane... is it ok (zcivic91)
Octane is a rating. It's a measure of a fuel's resistance to detonation. It isn't an actual ingredient.
Re: RACE GAS... 126 octane... is it ok (dustin)
ive heared high octance only comes in leaded fuel??? anyways run enough of it and ull kill the o2 sensors and the cat. i would unplug the cat before running it
Re: RACE GAS... 126 octane... is it ok (johnzm)
Sorry CA guys, us blown FL guys don't have to deal with nuisances such as cats...
jB
Re: RACE GAS... 126 octane... is it ok (PeloTudo AKA Gringo)
Do you lucky bastards run without o2 sensors too?
Cat....HAHAHAHAHROFLMAOMUHAHAHAHAHAHAHAHAHA....GAS P..........HAHAHAHAHAHAHAHAHAHAHAHAAHAHAHAHAAHAHAH AHAHAHAHAHAHAHAAHAHAHAHAHAHAHA
jB
jB
Re: RACE GAS... 126 octane... is it ok (hatchy)
jB
I'm a little hazy, but 104 octane is actually called C4 and 116 is C16, etc. The octane rating does mean the percent octane, but not really...that's why they switch over the the C-thingie, so you don't blow your mind thinking about 116% octane gas haha
I think somebody needs to the "The complete Idiots guide to internal comustion engines". Either that or its a trolls question looking for a flame war. Because somebod that askes that question doesn't know enough about engines to change the spark plugs much less build a tubo application. Anybody that knows anything about engines knows that 6 psi is not even 1/2 bar and that 12.5/1 compression engines ran on 100 octain fuel before engines had management systems and better designed combustion chambers. Or even really decent ignition systems.
[Modified by virginia_dude, 3:06 PM 9/27/2002]
Re: RACE GAS... 126 octane... is it ok (ion_four)
Actually, it is a particular chemical. C(8)H(18)
Well it made a lot more power that is for sure.. and what so your telling me that it would be a bad idea to waste 7 bucks a gallon.. i think it is worth it.. and on a turbo .. who has a cat.. i just got a 2 in down pipe..
Global Moderator
That is more worthwhile than running high octane.
There is NO WAY that made way more power unless you were running like 20 psi boost. 93 octane is more than you need tor 6 psi and racing gas is exessive octain and that would reduce your power as it burns slower creating less power. Race gas only helps if you are running enough boost to have detonation problems on a properly tuned set up. THis is common knowedge to those of us who know engines, and not by those of you who pump 93 octain into your Escorts (american ones) thinking that transforms your car into a fire breathing beast. Any fuel with higher octane than is needed to control detonation will make less power than the lowest octane fuel that does not detonate in your engine. NO 6psi boosted engine is going to benift from ANY racing fuel much less 126 octane.
Re: RACE GAS... 126 octane... is it ok (virginia_dude)
There was a post about making your own race gas (from Toluene sp?; a paint additive) does anyone know if this could mess anything up such as fuel lines/injectors/seals?
octane wont give you power stupid, more boost will, and a higher octane means for safer boosting up high.
Re: RACE GAS... 126 octane... is it ok (bretx0r)
shut the **** up.
Re: RACE GAS... 126 octane... is it ok (mitsuman)
The octane rating is how that particular blend of chemicals behaves relative to a concentration of pure octane.
Example - 93 octane gas has 93% of the detonation resistance that a pure(100%) concentration of octane would have. So a gas with an octane rating of 104 has 104% the resistance to detonation of a pure octane solution.
Re: RACE GAS... 126 octane... is it ok (B20C5 Turbo)
Don't waste your cash on it. Tell ya what just fill the tank 1/2 93 octane and 1/2 octane booster that you can pick up at Pep Boys. That's what I do...it shaves off like 1.0-1.5 seconds on my 1/4 mile times....
any idiot can post on the internet.
just remember that folks.
