TurboXS blow off problems.
Old Jun 7, 2008 | 10:10 PM
SXEtony's Avatar
Default TurboXS blow off problems.
Today i re-did the intercooler piping on my turbo ls i switched from a Greddy blow off to a TurboXS type-s. i didint change any of my vacccum lines and when i started it up and took it for a drive to make sure it still boosted fine and to make sure i wouldnt blow any couplers, i boosted about 5 pounds in second gear and and when in shifted into third the bov didnt open, the turbo just surged like crazy. i know i have it hooked up right. i'm not sure why it would cause the turbo to surge. it came with a bunch of washers to put in the blow off to stiffen the spring. but im sure it doesnt need to be stiffened.
Any input?
Old Jun 7, 2008 | 11:32 PM
b16bri's Avatar
Default Re: TurboXS blow off problems. (SXEtony)
Well usually when you have compresser surge it's b/c it's to stiff and not opening try and losen it
Old Jun 8, 2008 | 09:58 AM
albciivic's Avatar
Default Re: TurboXS blow off problems. (b16bri)
ya but he only has the normal spring it came with in the blow off. he didnt add washers.. thats the confusing thing. why wouldnt it release the pressure?
Old Jun 8, 2008 | 11:21 AM
SXEtony's Avatar
Default Re: TurboXS blow off problems. (albciivic)
BUMP need to get this fixed
Old Jun 8, 2008 | 03:35 PM
blakkvtec's Avatar
I had one, same problem.There for cars with high boost tho. I now have a hks and works fine with same vac source. The spring in the rfl is to hard. So run 20psi or get rid of it.
92EgDelsol
May 5, 2015 12:21 PM
Hmotoredcoupe
Jul 22, 2008 06:46 AM
dturbo
Apr 11, 2006 07:03 PM
Cashflo
Aug 15, 2002 03:27 AM
reefer_bob
Jan 8, 2002 02:54 PM
