Turboknowledge
Old Apr 18, 2004 | 06:31 PM
'05 SubyD's Avatar
Default Turboknowledge
ehh ive searched, and have simple questions. Im running (stock internal) d16z6 k so im planning on doing boost. What I really wanna know is what are my minimum necessesary parts are going to be for running 6-7 pounds? is running without forged pistons, rods, sleeved block, etc. on 6-7 lbs gonna hurt my engine? thanks for input.
Old Apr 18, 2004 | 07:06 PM
Harry Doyle's Avatar
Default Re: Turboknowledge (JDCiv)
you dont need internals for that amount of boost, just bolt on the kit and get it tuned
Old Apr 18, 2004 | 07:08 PM
5STAR3's Avatar
Default Re: Turboknowledge (Harry Doyle)
wow, must have searched pretty hard.....
no, you dont need a built block for 6-7 pounds.
Old Apr 18, 2004 | 07:12 PM
92jdmhatch's Avatar
Default Re: Turboknowledge (envision2teg)
well everyones right you probably dont need any internal work...but just to be on the safe side...i wouldnt boost 6-7 daily and i would invest in at least better valvesprings thats all....and make sure wut u already have is in good condition: timing belt ( it ripped on me and it was bad) head gasket ( dont wanna blow it ) air to fuel ratio, and your coooling system (radiator has no leaks) and just get it tuned youd be okay
Old Apr 18, 2004 | 07:27 PM
m R g S r's Avatar
Default Re: Turboknowledge (92jdmhatch)
^You wouldn't run 6-7 lbs daily? Are you kidding, that's considered low boost for that engine. What do you want him to run, 2lbs? And a turbo has nothing to do with the engine reving high, that has to do with the driver. So why would he need valvesprings?
Old Apr 18, 2004 | 07:56 PM
boosted_dc2's Avatar
Default Re: Turboknowledge (m R g S r)
valvesprings??? um....yea okay.
Landon
Old Apr 18, 2004 | 08:22 PM
92jdmhatch's Avatar
Default Re: Turboknowledge (boosted_dc2)
my bad guyz...im soo not in it today..not valve springs i meant pistons....
Old Apr 18, 2004 | 10:26 PM
AspectIndustries's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92jdmhatch &raquo;</TD></TR><TR><TD CLASS="quote">my bad guyz...im soo not in it today..not valve springs i meant pistons....</TD></TR></TABLE>
Umm, ok...........?
why not invest in some rods while you at it?
THat motor should be able to handle that amount of boost. -
Old Apr 18, 2004 | 10:33 PM
92jdmhatch's Avatar
Default Re: Turboknowledge (synik)
why not built your entire block then and boost 14lbs?
Old Apr 18, 2004 | 10:42 PM
MikeMAN's Avatar
engine internals are dictated by the amount of POWER they will be producing, not their boost level.
Old Apr 18, 2004 | 10:46 PM
92jdmhatch's Avatar
Default Re: Turboknowledge (MikeMAN)
i c...soo if you have a alot of internal work...doesnt that mean you can boost more?
civproject14
Jan 31, 2005 05:19 PM
974drgs
Nov 5, 2003 02:46 PM
cascivic
Mar 5, 2003 05:20 PM
gigantor
May 22, 2002 02:53 PM
AshlandSi
Nov 15, 2001 05:29 PM
