how much boost can i run on a non-sleeved block?
i'm using srp 8:5.1 pistons, eagle rods, cometic head gasket, arp head studs, etc. the block is not yet sleeved, but i was thinking in 15-18 lbs range. is that possible? it's a b16a2.
Re: how much boost can i run on a non-sleeved block? (b16blacksi99)
First of all, what turbo is this on? If it's some little T25 then I'd say sure. If it's a SC61 or something of that nature, I'd say you better have some C16 and a good tuner on your side, not to mention a large meat sack. Some people will say it can be done no problem, some will say that you'll at least need a block guard, but everyone single person should agree that no matter how you wanna do it, tuning is of the utmost importance. Good luck and let us know how it turns out!
Re: how much boost can i run on a non-sleeved block? (Disco Stu)
Read this: https://honda-tech.com/zerothread?id=494193
Re: how much boost can i run on a non-sleeved block? (jinxproof99)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jinxproof99 »</TD></TR><TR><TD CLASS="quote">i like to run between 11 and 67 lbs of boost. somewhere in that range.</TD></TR></TABLE>
I've quit using this account
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Disco Stu »</TD></TR><TR><TD CLASS="quote">First of all, what turbo is this on? If it's some little T25 then I'd say sure. If it's a SC61 or something of that nature, I'd say you better have some C16 and a good tuner on your side, not to mention a large meat sack. Some people will say it can be done no problem, some will say that you'll at least need a block guard, but everyone single person should agree that no matter how you wanna do it, tuning is of the utmost importance. Good luck and let us know how it turns out! </TD></TR></TABLE>
will a t25 push 17-18 psi without being outta is range? i thought at that psi is just blowin hot air?
Re: how much boost can i run on a non-sleeved block? (llewsirc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by llewsirc »</TD></TR><TR><TD CLASS="quote">
Well, they may not be very efficient but, I do actually know of a local guy running 23psi (he claims) on his t25 and even on his stock sidemount. I've seen the car go mid 11's, but he probably had a differenet turbo on their at that point. He did say that at that level, he had a very hard time keeping the boost constant though. I realize that that doesn't really answer your question, but I figured I'd throw that in their.
