Turbo Help
Old Apr 18, 2004 | 08:55 PM
blownD16's Avatar
Default Turbo Help
I'm running a '02 WRX td04 on my '92 si. My problem is that for some reason my turbo is blowing oil out my exhaust and into my charge pipe. I recently had the turbo checked out. There is nothing wrong with the seals or anything . Is it possible to be running too large of a feed line? I'm running an 1/8 inch hard line from the back of my block. and a #10 return line (which is only about 7 inches long). I'm just at a loss. Greatly appreciate any help, Thanks.
Modified by blownD16 at 6:08 AM 4/19/2004
Old Apr 18, 2004 | 10:26 PM
blownD16's Avatar
Default Re: Turbo Help (blownD16)
Bump
Old Apr 18, 2004 | 10:35 PM
MikeMAN's Avatar
your feed may be also mounted too low, or might slightly be going upwards which is causing oil to get backed up into the turbo and being burnt
mike
Old Apr 18, 2004 | 11:19 PM
gdrum's Avatar
Default Re: Turbo Help (MikeMAN)
or you filled your car with to much oil...ive seen that happen to...friend put to much oil in his car and it backed up smoked like bia
G-Auto*Hero
Jun 4, 2009 07:26 PM
boostedcoupe1
Feb 20, 2008 01:55 PM
SpoolnByYou
Nov 20, 2005 07:04 AM
J_Pemb
Jun 30, 2005 08:01 PM
QWKVTEC
Apr 19, 2004 08:45 AM
