TurboEdit : Where can I find the most info/forum/maps etc for the program
Basically I wanna learn and run turboedit on my obd0 dohc zc.
I have a chipped pm6 ECU from another build.
Is there a forum or guideline for TurboEdit at this time which would help learning about it and people to help set it up/ tune.
Before I even go turbo Id like to try out the ECU with a stock dohc zc map on the chip and see how it runs N?A, and make sure it still works.
Can you download TurboEdin bin files?
Is tehre a current version, or maybe a previous version is better somehow??
Help me run TurboEdit!!
Who is Mr Robot?
Re: TurboEdit : Where can I find the most info/forum/maps etc for the program
pgmfi.org
turboedit is as old as time, so good luck finding anything newer
Good, Bad…I'm the one with the gun
Location: Trapped in time, Surrounded by evil, Low on gas
1 Post
You have your answer. Consider going OBD1 Neptune/Hondata.
Thanks I guess. I cant stray from obd0 though, it would be me in a different emissions testing procedure that I would fail
