turboedit help...
Old Nov 14, 2004 | 11:05 PM
mattcalica's Avatar
Default turboedit help...
i know that while using the hack, it manipulates the map sensor readings and can cause the timing to advance, but i wanted to know if I use the hack, but enable the boost retard function on turboedit, will the hack still cause timing issues? I was thinking about adding -.75 boost retard, but using the vafc to tune the fuel because i dont have a laptop to tune off of, and there is nobody in hawaii that knows how to use turboedit...so will this be safe? Is the boost retard function on turboedit the same thing as using a msd btm? any help would be appreciated.
Old Nov 15, 2004 | 02:20 AM
Boosted Chemist's Avatar
Default Re: turboedit help... (mattcalica)
u can fine tune with the vfac and be safe, then u should take your data and burn a new chip based on your vfac setttings
Old Nov 15, 2004 | 11:55 AM
mattcalica's Avatar
bump
Old Nov 15, 2004 | 03:03 PM
mattcalica's Avatar
ttt
Old Nov 15, 2004 | 08:45 PM
mattcalica's Avatar
hmmm, maybe i should have chose a different post title...not getting too many responses...
Old Nov 15, 2004 | 11:55 PM
mattcalica's Avatar
damn, wheres all my freeware tuners at? only one reply in one day? cmon, someone help please?
Old Nov 17, 2004 | 02:01 PM
mattcalica's Avatar
Default Re: (mattcalica)
bump
Old Nov 17, 2004 | 02:38 PM
93turbo16's Avatar
Just tune as close as you can with turboedit. Put it on a dyno and do it yourself, you can keep reburning chips untill you get them right. but yea if you run a boosted map, you can use vafc to fine tune, but I would pull more like .9 deg/lb out because you don't know how much you are going to be playing with it. I would just tune straight off turboedit, no reason not too.
Old Nov 17, 2004 | 03:22 PM
xenocron's Avatar
Default Re: (93turbo16)
let's see...
you dont need a laptop to tune with turboedit, you just need a computer, a chip burner and of course some chips
Do you have a wideband? You cant really tune without one of those but I didnt see you mention it.
What I used to do when I first started out with TurboEdit (before any kind of datalogging) is I would go out for a ride and try to hit all sorts of spots in the fuel map, and I would pay attention to what RPM I was at, what Load (boost/vacuum guage) I was at and what the AFRs were reading when I was at that spot. I would try and hit 4-5 spots (and even write them down sometime to be sure I remembered). Then I would come home and make changes in those specific areas, reburn and then go out for another drive. Sometime I would burn 2-4 chips...and see how much larger or smaller increases in 'problem' spots would affect them...and choose the best.
Its really prety easy once get get going...and then like someone said, after you get a decent tune down, take her to the dyno, see if you can get some fine tuning down. Negotiate ahead of time that you will be installing TurboEdit on one of their shop computers....hell, see if they will give you discounted dyno time if you show them how to use it. Shops are always trying to expand their horizons.
I also made a little Tuning with TurboEdit wirte-up.
Hopefully it might help you some more.
http://www.xenocron.com/te/fueltuning.htm
You really dont need the AFC any more, you could sell it and maybe buy a nice Electronic boost controller or put it towards a wideband (if you dont have one)
Old Nov 17, 2004 | 04:31 PM
mattcalica's Avatar
well, i have a wideband...so my plan was just to street tune it...in my opinion, playing around with the vafc is a lot easier than changing around the fuel maps via computer, so thats why i wanted to keep the vafc, but again, will running a boost retard program on turboedit prevent the timing advance with transistioning into boost with the hack?
Old Nov 17, 2004 | 06:14 PM
sleepin91teg's Avatar
the man who designed TE just told you what to do (xenocron) if you feel the boost retard being necessary, then run it
Old Nov 18, 2004 | 06:56 AM
xenocron's Avatar
Default Re: (sleepin91teg)
haha...i didnt design it, im just a TE ***** and do a lot of the 'support' on it
to answer your question about the hack...if you use the boost retard maps of TE, you have to use the boost fuel maps as well. you have to create an entire grid...thus no longer using the 'hack' basically.
make a basemap using TurboEdit...spend two hours tuning it with the chip & computer...and then if you find spots later, tweak them with the AFC
Old Nov 18, 2004 | 11:41 AM
mattcalica's Avatar
sounds like a plan to me...thanks a lot xenocron!
Old Nov 18, 2004 | 04:29 PM
xenocron's Avatar
np, glad i could help!
mattcalica
Oct 4, 2004 09:48 AM
jetpilot
Apr 5, 2004 11:01 AM
dirtySOHC's
May 17, 2003 03:28 PM
echo999
Dec 31, 2002 11:28 AM
willyboyK20
Oct 30, 2002 09:50 PM
