adding BTM = re-tune?
Old May 15, 2003 | 12:22 AM
dirtySOHC's's Avatar
Default adding BTM = re-tune?
i want to purchase an MSD BTM. my question is, will i have to re-tune the fuel map i already have set on my AFC (hack)?
I just tuned about a month ago and i didnt plan on going back for a while. running around on a 4 degree retard kinda sucks. i would rather have the BTM so it adjusts the timing accordingly............my car sees about 4.5 psi daily, if that.
Old May 15, 2003 | 04:03 PM
Default Re: adding BTM = re-tune? (dirtySOHC's)
bump
Old May 15, 2003 | 04:09 PM
boostincoupe's Avatar
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
good question...I'd like to know this as well
free bump
BTW, what's your AFC hack settings? I have the same motor with a greddy kit.
Old May 15, 2003 | 04:12 PM
Default Re: adding BTM = re-tune? (fnananon)
i dont have them on me right now. i am at work. they vary from -26% to -41% or so.
Old May 15, 2003 | 07:26 PM
TeStUdO's Avatar
well, if you are only running 4-5 psi daily, i wouldnt even retard the timing. but if you use the btm get it tuned again on a wideband dyno and you might not have to retard the timing so much and make more power
Old May 15, 2003 | 07:34 PM
Default Re: (TeStUdO)
my car is tuned for 8psi. i was saying that daily driving i only see 4.5 psi if even that much. driving around on a 4 degree retard isnt all that great and being that i dont see 8 psi everyday its pretty worthless having it retarded so much.
Old May 15, 2003 | 10:16 PM
Default Re: (dirtySOHC's)
bump
Old May 15, 2003 | 10:33 PM
swrdply400mrelay's Avatar
The best way is probably to get your car re-tuned, but if it were me and I didn't have the money to retune it, I'd just set your timing on the dizzy back to stock. Then crank the the BTM to something from 0.5 - 0.75 degrees/psi until you can get it tuned again.
Old May 16, 2003 | 02:56 PM
scttydb411's Avatar
definately retune. you are 4 degree retarded right now, but when you return to stock timing and use btm you will not retard 4 degree until hitting 8psi at .5 degree/1lb of boost. might not hurt, but you will constantly question any little tick or rattle while boosting.
Old May 16, 2003 | 03:11 PM
Default Re: adding BTM = re-tune? (scttydb411)
i dont know how you guys here detonation under boost. between the turbo spooling, motor noise, exhaust and the wastegate dumping it is hard to hear. the only way i know is if i check my plugs
Old May 16, 2003 | 04:21 PM
scttydb411's Avatar
i agree. what i'm saying that any noise will induce paranoia or constant worry. it's like 100bucks to get dyno tuned...definately worth it to not worry about having to replace anything.
Old May 16, 2003 | 04:48 PM
oh im paraniod about every damn thing. i pull over on the sides of raods just to check it out. call me crazy.
Old May 16, 2003 | 06:28 PM
zojirushi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dirtySOHC's &raquo;</TD></TR><TR><TD CLASS="quote">oh im paraniod about every damn thing. i pull over on the sides of raods just to check it out. call me crazy.</TD></TR></TABLE>
thats the reason why i don't drive my car often
Old May 16, 2003 | 08:15 PM
CivicSoul's Avatar
Default Re: adding BTM = re-tune? (zojirushi)
I was told, no need for BTM under 10 psi while running 93 octane. I feel like it could not hurt taking off .25 per pound for safety but they are telling me to sell it. What are your opinions? I am currently running 9-10 pounds with stock timing
Old May 17, 2003 | 06:02 AM
scttydb411's Avatar
Default Re: adding BTM = re-tune? (CivicSoul)
it would be good to keep it just in case the car gets out of tune (ie: accidently get bad gas, temperature/humidity/elevation extreme change, etc). then you can take some timing out if needed.
Old May 17, 2003 | 09:10 AM
Pritos's Avatar
New User
keep in mind that I have my MSD6ABTM for sale. It's been on my EG for 3 years without problem. drop me an email if interested!
Old May 17, 2003 | 03:28 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicSoul &raquo;</TD></TR><TR><TD CLASS="quote">I was told, no need for BTM under 10 psi while running 93 octane. I feel like it could not hurt taking off .25 per pound for safety but they are telling me to sell it. What are your opinions? I am currently running 9-10 pounds with stock timing</TD></TR></TABLE>
wow. i never heard anyone running stock timing at that much boost. i only get 91 octane out here and i am at an elevation of about 4800ft. so all that kinda changes things for me.
98GSR-Turbo
Dec 16, 2007 08:36 PM
94ta_lt1
Dec 25, 2004 03:45 PM
jetpilot
Apr 5, 2004 11:01 AM
twkdCD595
Feb 14, 2004 11:48 AM
nigel
Aug 23, 2003 10:32 AM
