Turbo will not clock
Hello-
I am in need to clock my t3/t4 from a drag kit, and the turbine wont budge. I loosened all 6 bolts and the center cartridge still wont turn. The compressor turns just fine however. There is no shaft play (if that matters) and the wheel spins freely. The turbo has ~ 1000 miles on it.
Any advice?
Any advice?
It's not going to move without removing the entire assembly, loosening the bolts very carefully, and using a rubber mallett knocking in a circular pattern at 12 o'clock, 3 o'clock, 6 o'clock, 9 o'clock points several times.
Most of the time the compressor housing just needs to be clocked unless going w/ a top mount manifold.
thanks for the advice. The turbo was originally clocked, and i need to re-clock it
Also the person who did my oil return for me kinda messed it up and I cant fix it without clocking it
thanks, ill see if that works.
Try putting the turbo in a vise. Soak the bolts some kind of oil to maybe loosen them up.
The rubber mallet is a good idea, but just becareful you dont knock the housing loose causing damage to the wheels.
