clocking a turbo, need it to be balanced?
Old Oct 28, 2006 | 07:28 PM
tehdvd's Avatar
Default clocking a turbo, need it to be balanced?
Hi,
I have a gt2510 turbo which I need to convert to a top mount. I couldn't get the snap ring off one of the housings so i just unbolted some of the side bolts instead and I was able to then clock the compressor side housing. The exhaust housing side was easier to loosen since it just required bolts and a hammer . But my question is, would the turbo be off balanced or something since I did this method instead of the correct way, which i think is to take the snapring off and rotate the center housing only?
Old Oct 28, 2006 | 07:43 PM
b20turboic's Avatar
Default Re: clocking a turbo, need it to be balanced? (tehdvd)
the housings have nothing to do with the balance of the wheels. The center section is balanced.. you can change out housings and it will be ok. So clocking and moving them is ok to do as well.
Old Oct 28, 2006 | 08:01 PM
turbotime's Avatar
yup ^ is right clocking has nothing to do with balancing
Old Oct 28, 2006 | 08:30 PM
JDMRice's Avatar
I had to rotate both housings, youll be fine.
Old Oct 29, 2006 | 01:22 AM
tehdvd's Avatar
thanks for all the replies. I was expecting some flaming going on from all the stereotype about this forum, but they're probably wrong. Thanks
Old Oct 29, 2006 | 01:24 AM
Schister66's Avatar
Man U FTW
i move my housings all the time....no bid deal.....you're fine
Old Oct 29, 2006 | 03:35 AM
BoostedEG6's Avatar
Default Re: (tehdvd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tehdvd &raquo;</TD></TR><TR><TD CLASS="quote">I was expecting some flaming going on from all the stereotype about this forum, but they're probably wrong. Thanks</TD></TR></TABLE>
Just give it time they dont call this place hater-tech for nothing
But they are all correct about the housing
Tippyman
Jun 1, 2007 02:53 PM
mnlude
Mar 7, 2006 10:22 AM
B18EG6
Jan 28, 2006 04:24 PM
pro547
Jun 20, 2005 12:54 PM
slowdx
Sep 28, 2004 08:08 AM
