Is this turbo too small for my setup
Old May 21, 2010 | 03:12 PM
KdF's Avatar
KdF
Default Is this turbo too small for my setup
I've got an ls vtec that I'm about to boost.
It's gonna run crower stage 2 cams w an aebs manifold and 70mm tb
i'm looking for around 300-350 whp
the turbo
48AR turbine housing
compressor .60AR housing
60 trim wheel
Heres Turbo #2
Its a 50 trim
.42 a/r turbine housing
.48 a/r compressor Housing
when can I expect to start spooling and hit full boost?
Old May 21, 2010 | 03:49 PM
azandford's Avatar
Default Re: Is this turbo too small for my setup
its not too small it just may take more boost to make that power...
spool time depends on a few things... whats your setup like?
Old May 21, 2010 | 04:14 PM
KdF's Avatar
KdF
Its a stock LS bottom end with ARP Rod bolts.
Port and Polished b16 Head
AEBS Manifold, 70mm Throttle Body
Crower Stage 2 cams
Skunk 2 Pro Series Cam gears
Supertech Dual V/S, Titanium Retainers, and Valves
Old May 22, 2010 | 10:56 AM
KdF's Avatar
KdF
TTT
Old May 22, 2010 | 11:33 AM
delslow1975's Avatar
you can hit the power goal but i dont know if your stock bottom end will hold the psi that you will need to reach your goal. it should spool very quick unless the cams play a factor.
Old May 22, 2010 | 11:35 AM
KdF's Avatar
KdF
When am I expecting to hit full boost?
I wanna be at full boost at about 4500-5000 RPM, so i can daily drive outside of boost.
Old May 22, 2010 | 12:44 PM
spoolin turbo s's Avatar
the turbo
60 trim wheel
Heres Turbo #2
Its a 50 trim
the only way your going to get 350 whp is if you run both turbo's,,,,,,,,,,,run both and and it could make probably about 550whp max boost and then make 300-350 daily whp
seriously if youa capable of getting the manifold to do this?
Old May 22, 2010 | 03:17 PM
azandford's Avatar
you could probably hit 350 at 17-20psi with that 50 trim
i would just get a t3t4 57 trim and that power will be made on less boost and you wont be pushing the turbo to its limit
and you can dd the car and still get to 5k... just dont mash on it and it wont build boost
Old May 23, 2010 | 05:07 AM
th3pwn3r's Avatar
Uhh, engines hold psi unless they leak it all out.
This is kind of silly you don't want to daily drive while in boost so I suggest you get a daily driver and keep this car separate =/
Haha, I think you're trolling but the OP doesn't want to run a TT setup.
Haha, exactly. Usually when I don't want too much power I go easy on the gas pedal.
Old May 23, 2010 | 06:15 AM
KdF's Avatar
KdF
What about the 60 trim?
Old May 23, 2010 | 07:15 AM
azandford's Avatar
^ sounds good! i personally like my 50 trim because of the quick spool and around 300 is great for me because my clutch can hold it great w/o any slipping
Old May 23, 2010 | 04:30 PM
KdF's Avatar
KdF
60 Trim should still spool pretty quick, correct?
What clutch are you running..
Im looking at an ACT HD pressure plate and kevlar full face disk
Old May 23, 2010 | 04:57 PM
azandford's Avatar
yeah as long as your exhaust is adequate i.e. 3 inch
i run an stage 3 clutch..not sure the brand but it grips well
Old May 23, 2010 | 05:14 PM
KdF's Avatar
KdF
A stage 3 should handle more than 350 WHP.
Im gonna 3" back.
And now,the age old question.
B16 pistons in an ls block boosted.
I have a fantastic tuner, so High compression boosted...
Debate!
CRXherbie91
Mar 3, 2011 08:00 PM
turbo boost
Oct 16, 2007 02:24 PM
onemanlan
Dec 12, 2005 07:55 PM
untitled
Apr 15, 2005 05:14 PM
unknown user
May 7, 2002 09:07 PM
