Turbo and Timing, HELP
Old Feb 8, 2006 | 07:36 PM
A.E Motoring's Avatar
Default Turbo and Timing, HELP
well i kinda have a dilema here, i am going to be boosting in a couple of days, but thing is i'm kinda worried to boosting with the timing is advanced, it does have some things on the motor its a GSR with CTR cams, Skunk 2 intake mani, and a Spoon TB, so i'm guessing the last owner of the car advanced the timing for some reason (guessing cause of the things on the motor) i just put my apexi cat back on too if that matters, but anyways just wondering if it would be ok to boost on the timing that its on, thats wats keeping me away from boosting the car, the timing.
its going to be untuned for now its going to be running on a FMU for now on stock injectors, i bought the kit used and the previous owner was boosting 6 to 6.5 pounds off the wastegate untuned. So wondering if it would be safe.
Old Feb 8, 2006 | 07:38 PM
PrecisionH23a's Avatar
Default Re: Turbo and Timing, HELP (SPNFEDEH)
No, it won't be safe.
At least pull a bit of timing at the dizzy. Rule of thumb is .75 retard per psi of boost. Do a search on tuning... you'll find a lot of useful info. You can also check out http://www.hondata.com for some good info.
Old Feb 8, 2006 | 07:55 PM
Default Re: Turbo and Timing, HELP (PrecisionH23a)
but the car wont be tuned for a lil while not, maybe i can just go to a shop and have the retard the timing for me or something???
well i guess my boosting days are put on hold then, haha
Old Feb 8, 2006 | 07:59 PM
Honestly... wait until you have the funds to properly tune the car.
FMU's suck ***. End of story.
Old Feb 8, 2006 | 08:03 PM
yea i know they do, wat if i get my timing set back to stock? woudl that make it any easier? i was reading on hondata that ppl do boost there cars on stock timing.
Old Feb 8, 2006 | 09:03 PM
or wat least wat should my timing be with those parts on the car????
Old Feb 9, 2006 | 10:52 AM
Old Feb 10, 2006 | 01:28 PM
Old Feb 10, 2006 | 01:38 PM
stewie8apie's Avatar
i boosted my car with an fmu, stock injectors, and untuned at 7psi.....it only took a week to blow it. maybe that will help your decision. get a wideband, some sort of engine management (i.e. uberdata, hondata), injectors, and a better fuel pump and GET IT TUNED. Otherwise you have just thrown all of your money into a black hole like i did.
Old Feb 10, 2006 | 01:46 PM
Default Re: Turbo and Timing, HELP (stewie8apie)
damn brah, lol yea that helped me ALOT, sorry about your blow up
Old Feb 10, 2006 | 03:30 PM
spoon95eg's Avatar
B A N N E D
From: Orange County / Palm Springs 714/76hoe, ca, usa
Put on stock timing and put the turbo and everything except fmu and run the stock injector is better than fmu for awhile I think and then when u get ur money chip the ecu to uberdata or crome and tune it that the most important thing in turbo honda I forgot buy some bigger injector 440cc or 550 cc and ur good to go and I forgot i f ur car has the stock clutch change it b4 u do the dyno so u won't get anyproblem later cuz mine slips while dynoing it so yea good luck
Benjithx
Jan 13, 2005 11:01 AM
bmm89
Nov 21, 2004 08:17 PM
B_1_8_hatch
Jul 28, 2003 01:33 PM
Fatty_1775
Nov 13, 2002 06:33 PM
808eg6
Jun 24, 2002 07:52 AM
