boost in gear driving but not in neutral
Just like the post says, i get 9psi while driving but if i am in neutral and rev it or on the clutch and rev it i do not create any boost. What can cause this!? thanks, Jim
wow....are you serious...i hope ur joking
if not
the answer is
the motor has no-load on it...and you probably don't have a ball bearing turbo....and u probably don't have a tiny turbo
hope that help's
if not
the answer is
hope that help's
Re: (lucidvtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lucidvtec »</TD></TR><TR><TD CLASS="quote">
the motor has no-load on it.</TD></TR></TABLE>
Re: (90AcuraIntegra04)
When you rev in neutral, the engine has no load on it which means it stays in high vacuum and the injector flow is minimal.
Minimal injector flow = minimal exhaust flow = turbo won't spin = no boost.
Re: (EnzoSpeed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EnzoSpeed »</TD></TR><TR><TD CLASS="quote">When you rev in neutral, the engine has no load on it which means it stays in high vacuum and the injector flow is minimal.
Minimal injector flow = minimal exhaust flow = turbo won't spin = no boost.</TD></TR></TABLE>
Re: boost in gear driving but not in neutral (90AcuraIntegra04)
if u want boost in neutral u need a 2step, that will help create extra pressure/load to build boost
good luck
d
good luck
d
someone explain to me why he wants boost in neutral anyway?.........are you going to go fast in neutral?....just seems like a sure way to mess a car up
Re: boost in gear driving but not in neutral (hYbRiD EeEkAy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hYbRiD EeEkAy »</TD></TR><TR><TD CLASS="quote"></TD></TR></TABLE>
hahaha
hahaha
Re: boost in gear driving but not in neutral (Muckman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman »</TD></TR><TR><TD CLASS="quote">He wants to blow off at ppl by reving at them.</TD></TR></TABLE>
dingdingding
dingdingding
i wanna be a EVO,SRT4...with a tiny turbo so i can do my BOV in netural at stop lights...that would be so cool.....anywhoo i just got in my altezza'a and my "v-battle GTR wing"
NAAZ is next....
lmao.....jp
NAAZ is next....
lmao.....jp
Re: boost in gear driving but not in neutral (TEG777)
my old ht set up used to crack my friends and I up. I could free rev that bitch to 9#
like nothing. It was a dinky *** t25 on an 89 teg motor in an 86 si hatch. Thing was
quick and did some hella smokies!!!
Re: boost in gear driving but not in neutral (0x64)
Boost in neutral? Huh?
Easy to do just DOWNGRADE whatever turbo your using to either an RHB5 or something similar like a very small T25 and you will be boost like 8psi in neutral man YAYY BUDDY!
"i can blow off my valve now but i can't beat the 3-cyl Geo metro next to me WTF is wrong?"
seriously the rhb5 is practically maxed out in neutral anyways so you can have all the fun you want in neutral.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90AcuraIntegra04 »</TD></TR><TR><TD CLASS="quote">yea its a farley big turbo and its a wet floating turbo. I was guessing it was the load thing but idk? </TD></TR></TABLE>
wet floating turbo = SSAC description.
Who is Mr Robot?
its also an ssac turbo too
edit: **** beat me to it, lol
Re: (wantboost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 0x64 »</TD></TR><TR><TD CLASS="quote">What will boost do in neutral for you? Your not going any where.</TD></TR></TABLE>
so you can launch in boost.
