was reading the 2001 HCI and the Junkyard turbo..........
they used a svo turbo non intercooled with stock fuel pump and stock injectors, inline fuel pump and 8:1 fmu and they ran 6psi. so i was going to use 12:1 fmu with inline pump stock pump and injectors. running 6psi. so should i get the 8:1 or stay with my 12:1 i'm just mixed up.
THANKS
THANKS
Re: was reading the 2001 HCI and the Junkyard turbo.......... (CIV616)
a 12:1 with your stock pump will have trouble pumping that much pressure at 6psi of boost. if you can, i would go with the 8:1 that way you can make to 6psi with no problems, that is if you use 310cc injectors
Re: was reading the 2001 HCI and the Junkyard turbo.......... (CovertFI)
so what do i do i'm have stock injectors i have inline fuel pump and i'll be running 6psi they ran 6psi with inline and 8:1 disk. what to do......
[Modified by CIV616, 5:29 AM 8/6/2002]
