oil return bung to low??
Old Aug 20, 2009 | 04:03 PM
thegatekeeper14's Avatar
Default oil return bung to low??
i welded my oil return from my turbo about 1 inch from the bottom of the pan, is that too low?
Old Aug 20, 2009 | 05:37 PM
srmofo's Avatar
Default Re: oil return bung to low??
yup...oil coming out of the turbo is kinda foamy , so it wants to sit on top of the oil. Your return is below the oil level in the pan....Do you see where that is gonna be a problem? No problems though just put a cap on it and weld another bung above it, just make sure you leave ebough clearance to screw the fitting on
Old Aug 20, 2009 | 07:29 PM
how long will this be a problem, will it be ok to tune my car like this and change it after or should i take care of it b4 the tune?
Old Aug 20, 2009 | 07:38 PM
srmofo's Avatar
well its gonna cause oil to back up in the turbo, sooo when you start to see smoke you know its a problem, personally I would fix it first but its your turbo seals, so do what you want
Old Aug 20, 2009 | 07:44 PM
well its a gt35 so i guess i better replace it lol
Old Aug 20, 2009 | 08:20 PM
redzcstandardhatch's Avatar
something different
NOT NECCESSARILY
many many many aftermarket turbo kits use a banjo fitting in the oil drain plug for the return. thats the LOWEST POINT.
the oil level in the line will never be higher than the oil level in the oil pan. if the turbo its above that level, you SHOULD be ok. many smoky turbos have happened due to what people thought was either a dead turbo, too much oil pressure, or poor drain location. usually the real problem is crankcase pressure backing up into the turbo, cause they boosted an OLD motor with a stuck PCV valve.
if the turbo is up nice and high, you should be ok, realistically. the "up high" oil drain isnt as important as people thought in the past. we've put MANY MANY oil drains below the oil level , with no problems due to drain placement
Old Aug 20, 2009 | 08:46 PM
90blackcrx's Avatar
Originally Posted by redzcstandardhatch
NOT NECCESSARILY
Very well put said, listen to this man, besides knowing a lot, he is very sexy looking in his hatch.
Old Aug 20, 2009 | 09:47 PM
Adam_b16a's Avatar
lol wtf??
Old Aug 20, 2009 | 09:53 PM
b20beast83's Avatar
great info
Old Aug 20, 2009 | 09:56 PM
b20beast83's Avatar
Originally Posted by Adam_b16a
lol wtf??
x2 wtf
Old Aug 21, 2009 | 04:14 AM
something different
haa
lol @ bob
Old Aug 21, 2009 | 07:05 AM
srmofo's Avatar
Im not saying it is gonna be without a doubt a problem but why take the risk with a $1200 turbo? even you said "you should be ok"...I dunno, maybe its just me.....wheres your oil drain located?
Old Aug 21, 2009 | 07:31 AM
90blackcrx's Avatar
lol wtf??
Only stating the truth.
Old Aug 21, 2009 | 08:45 AM
im using a top mount mani! so you guys say it shoild be alright
Old Aug 22, 2009 | 04:05 AM
something different
mine is located at the middle of the pan. well under the oil level.
set up everything else right, and you'll be FINE. promise
Old Aug 22, 2009 | 04:18 AM
tw1tch's Avatar
Who is tuning it?
Old Aug 22, 2009 | 12:08 PM
Blaze45's Avatar
Brrraaaap!
Dont put the drain too high, or right under the 10mm bolt/stud for the oil pan... Then you cant get the nut or bolt in when putting the oil pan back on... Dont ask me how I know...
Old Aug 22, 2009 | 12:42 PM
Spaceballsthelunchbox's Avatar
No Big Whoop
While we are at it. What about the right hose size for the oil drain.
Is 1/2" Inside Diameter too big or about right?
Old Aug 22, 2009 | 12:56 PM
something different
i dont think you can EVER go to big with a drain hose, it'd be impossible, only to small.
Old Aug 22, 2009 | 03:18 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Old Aug 22, 2009 | 04:31 PM
MAP is tuning
dart2.2
Jul 25, 2008 07:01 AM
pokmijn
Jul 21, 2007 11:45 PM
ITS_Dunn
Mar 16, 2006 04:51 AM
Snafu-Si
Jan 22, 2005 10:21 AM
cokex
Oct 17, 2002 01:09 PM
