Turbo question!
Old Nov 2, 2001 | 10:20 AM
Leimokei's Avatar
New User
Default Turbo question!
what's the highest boost you guys run at without killing your motor? I have a b18b1, with some forged pistons and crower cams...(wondering if i can push 13psi....need help! thanks!
Old Nov 2, 2001 | 12:34 PM
Integra187's Avatar
Default Re: Turbo question! (Leimokei)
hey u switched out your auto tranny, let me know if u want to sell your torque converter?
Old Nov 2, 2001 | 01:13 PM
Leimokei's Avatar
New User
Default Re: Turbo question! (Integra187)
yea i'm probably gonna get rid of it...i'll let you on wednesday next week?
how does $350 sound?
Old Nov 2, 2001 | 01:28 PM
Ricehornet's Avatar
I'd rather spend money on crower rods than the cams. Cams wont really be bearing the brunt of the increase in torque (turbos increase torque by making more pressure in the cylinder, so you increase power also)...the bottom end will take most of the beating, the pistons as the front line, and the rods for having to transfer all the power to the crank, the rods can bend, snap, you name it.....so if i were you i'd get the forged pistons and some nice forged rods as well.
Old Nov 2, 2001 | 01:47 PM
Leimokei's Avatar
New User
Default Re: Turbo question! (Ricehornet)
thanks...yea i think the bottom end will need to be built...any ideas on where i can get some good rods...i'm planning just to run 13psi...all the way...
Old Nov 2, 2001 | 02:12 PM
Ricehornet's Avatar
https://honda-tech.com/zerothread?id=83454
https://honda-tech.com/zerothread?id=77763
https://honda-tech.com/zerothread?id=81918
https://honda-tech.com/zerothread?id=50282
[Modified by Ricehornet, 6:15 PM 11/2/2001]
Old Nov 2, 2001 | 02:51 PM
Leimokei's Avatar
New User
thanks
Old Nov 2, 2001 | 04:01 PM
Vtec integra's Avatar
just need some bigger injectors. i dont know about 13 psi though
but 12 is pretty safe on bigger injectors and your set up
Old Nov 2, 2001 | 04:58 PM
Leimokei's Avatar
New User
Default Re: Turbo question! (Vtec integra)
thanks for all the replies, now i know what i need to do...
Old Nov 2, 2001 | 05:03 PM
Etylorcen's Avatar
With the right fuel and tuning you should be ok w/ stock internals at 12psi...stronger rods and valves would be a definate plus though. With that much boost though you're going to wear down your motor very fast. You definately will need a good clutch.
Old Nov 2, 2001 | 06:50 PM
Vazquez911's Avatar
Default Re: Turbo question! (Etylorcen)
No, you won't be OK with stock internals at 12psi... NOT worth the risk, I've heard of too many stories of people blowing things... Do it right, get the parts to "bulletproof" that motor... THEN crank the boost up.
Old Nov 2, 2001 | 08:22 PM
Integra187's Avatar
sounds good, its a level ten torque converter right. Let me know!
Old Nov 3, 2001 | 09:45 AM
Leimokei's Avatar
New User
yea its a levelten torque converter
Old Nov 3, 2001 | 04:27 PM
jinxproof99's Avatar
New User
Default Re: Turbo question! (Vazquez911)
or....keep your stock internals, add a inline pro headgasket, springs and retainers, fmu, afc, 440 injectors and run 15 lbs of boost w/ race gas to 8000 rpm's.
homicydalboy
Apr 12, 2007 01:14 AM
altz
Feb 25, 2006 06:30 PM
jdmjeff
Feb 14, 2005 01:16 PM
swpdb16
Oct 23, 2002 10:06 PM
Rratedcivichatch
Sep 12, 2002 09:16 PM
