turbo problems
Old Aug 2, 2003 | 09:16 PM
1dumbscreenname's Avatar
Default turbo problems
So i was at the track the other day wih my "new to me" greddy kit and wasnt looking for times as i was looking for trap speed because i have a stock clutch that needs replacing. i have a d16y7 and had the boost at 5 psi intercooled. trap speed was 90mph @16.2 with a 2.7 60' (the clutch is slipping badly)
my question is, does this mph sound right and if so with tuning and 10 psi what should i hope for mph wise.
also, i have a MBC and i screwed the screw all the way in and it wouldnt boost above 5 psi. im not sure why but figured this is the place to go for an answer. any help will be greatly appreciated.
Old Aug 2, 2003 | 09:25 PM
shermanyang's Avatar
Default Re: turbo problems (1dumbassscreenname)
Whoa!! you have a MBC and you screwed it shut and it wouldn't boost over 5psi!! you've got problems there!! if you had done that the boost should of sky rocketed!! check for leaks and definately change the clutch. good luck...sorry i couldn't help too much, gotta go eat a late dinner!!
Old Aug 2, 2003 | 09:37 PM
psileepR's Avatar
New User
Default Re: turbo problems (shermanyang)
Thats about right for a totally screwed in manual boost controller. that should be the default setting on your wastegate. (totally screwed in)
on my turboxs manual boost controller every full 360 degrees (counterclockwise or open) is 1 pound more above the wastegate setting.
Old Aug 3, 2003 | 03:51 AM
my searches told me that if i screwed it in i would get mroe boost and out for less.
Old Aug 3, 2003 | 06:43 AM
falcongsr's Avatar
What is this crap?
Default Re: (1dumbassscreenname)
describe your exhaust setup please
Old Aug 3, 2003 | 08:56 AM
Default Re: (falconGSR)
2.5 inch dp and exhaust. greddy manifold and turbo.
the problem i have is when we frist had the kit on the mbc was set at 10 psi and i turned it down to 5 until i got the intercooler, now i cant turn it up.
also, i have a homemade mbc, i was thinking of getting a joe p? controller because it has a spring and ball inside. mine doesnt. could someone explain how this works??
Modified by 1dumbassscreenname at 6:44 PM 8/3/2003
civic-8442-
May 21, 2008 10:35 AM
turbojdmhatch
Apr 28, 2008 03:02 PM
B00STED Si
Jan 15, 2005 05:27 PM
Andrew 825SM
Oct 2, 2002 07:39 PM
