NEED HELP TURNING DOWN BOOST!!!
Old May 21, 2008 | 10:23 AM
civic-8442-'s Avatar
Default NEED HELP TURNING DOWN BOOST!!!
okay so here is the deal. i have a LS with the greddy 18g, dsm 450's, hondata s100. and my little brother has exact same setup s100 and ecerything and his starts spooling at 2800rpm's and afte i got tuned i started spooling at 4800 rpm's both of us on 10 pounds. so i adjusted the arm that goes to my flapper on my internal wastegate and closed it in a little more because it was spaced out alot more than my lil bro's and now i start spooling at 3k but im hitting 13-15 psi i tried adjusting my Manual boost controller to lower the boost but im still hitting 13 psi and on my boost/vacuum gauge its at 10 vacuum and before it was at 16 vacuum. i loosened the boost controller to turn down boost but it has no effect on the psi its still the same. i am getting retuned friday if i dont figure out how to turn the boost down will the shop be able to do it? any help is appreciated thanks for reading my novel lol..
Old May 21, 2008 | 10:26 AM
OMG B16's Avatar
Default Re: NEED HELP TURNING DOWN BOOST!!! (civic-8442-)
Re adjust the flapper back to normal. However it was before you touched it.
Old May 21, 2008 | 10:35 AM
i dont know the exact spot it was at thats the thing. and when i got tuned on 10 psi i wasnt reaching peak or full spool as the guy said or aomething like that. but basically i want to get tuned on 14 pounds friday yet if possible keep it to where it spools at 3k!!!?? no ideas?
NYCFINESTEG
May 22, 2005 05:42 PM
ochsy03
Mar 24, 2005 08:53 AM
haq
Aug 6, 2003 11:56 PM
Ray
Jul 7, 2001 07:34 PM
