turbo problems
Old Jan 17, 2003 | 11:29 AM
JimmyT89's Avatar
Default turbo problems
Hey guys, when i boost in first gear, its fine, and when i hit second around 4k the fuel seems to cut off. any idea of what this could be? also is it workth paying $50 for the missing link so i dont need check valves? Thanks
Old Jan 17, 2003 | 11:32 AM
Diego Boost's Avatar
Default Re: turbo problems (JimmyT89)
What kind of car and Turbo setup are you running?
Old Jan 17, 2003 | 11:36 AM
JimmyT89's Avatar
Default Re: turbo problems (99GSRT)
I have a drag gen 2 kit for my accord but i blew the motor so not my h23a is getting put in right now. I just want to prevent this problem with the h23a.
Old Jan 17, 2003 | 11:46 AM
What is your fuel setup?
Old Jan 17, 2003 | 11:49 AM
JimmyT89's Avatar
my fuel setup is stock besides the additional inline fuel pump that came with the kit. I know that i need bigger injectors and tunning but i figure that it shouldn't effect teh fuel cut.
Old Jan 17, 2003 | 12:42 PM
swrdply400mrelay's Avatar
I'm guessing you have an FMU that came with the kit as well?
Old Jan 17, 2003 | 12:45 PM
JimmyT89's Avatar
Default Re: turbo problems (swrdply400mrelay)
yes, i have the vortech 12:1 fmu.
Old Jan 17, 2003 | 12:49 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
how much were you boosting?
Old Jan 17, 2003 | 12:51 PM
JimmyT89's Avatar
Default Re: turbo problems (HybridcivicLS-T)
well before the blew my motor it was at 5psi. when i blew my motor, my wastegate got blocked and it hit 25psi on a stock motor= not good
Old Jan 17, 2003 | 01:05 PM
I was having the same problem with my car when I first installed my turbo and I had an Inline Fuel pump, stock injectors and an FMU, at 6+ PSI the boost would just drop out. My engine lasted one week before the Piston rings broke from detonation.
Old Jan 17, 2003 | 01:07 PM
Was it a Turbonetics Delta gate by chance? Mine took a ****. The Tial is 100x better.
Old Jan 17, 2003 | 01:08 PM
JimmyT89's Avatar
yea it was the deltagate. how did you fix the problem with the pressure releasing through the bov?
Old Jan 17, 2003 | 04:00 PM
IloveNewt's Avatar
how did ur wastegate get blocked?
Old Jan 17, 2003 | 04:34 PM
JimmyT89's Avatar
Default Re: turbo problems (MordecaiPSI)
I put the vaccum hose on the other hole on the wastegate and i pretty much got unlimited boost. so does anyone know why my fuel gets cut off?
Old Jan 18, 2003 | 08:44 AM
JimmyT89's Avatar
hey, i know somebody in the forum has to have this problem. please post to help me out because I want to get turbo running correctly. Thanks for the help.
hondaj05
Jul 22, 2006 11:53 PM
stussy8280
Sep 5, 2005 06:31 PM
94hybridcoupe
Apr 6, 2005 06:53 AM
Rob!
Aug 1, 2004 01:06 PM
SlowB16
Jan 27, 2002 11:15 AM
