Boost leak?
Old Apr 4, 2005 | 05:00 PM
nzrnk's Avatar
Default Boost leak?
How can you tell if there is a boost leak, will the boost gauge act funny, or any other sign, my car doesn't feel fast anymore
Old Apr 4, 2005 | 05:02 PM
LostCRX's Avatar
Default Re: Boost leak? (nzrnk)
if your turbo spool but you cant build boost then you got a boost leak.
Old Apr 4, 2005 | 06:50 PM
PrettyLude's Avatar
look at the boost gauge, and if you don't build any boost, you can definately hear it, plus the gauge will not read about 1 psi
Old Apr 4, 2005 | 09:00 PM
rioninja's Avatar
If its just a small boost leak, you will have a hard time telling. With a tiny leak you will most likely still hit your normal boost level, but your turbo will have to work harder to do it. A lot of times putting it out of its efficiency range.
Only sure-fire way is to test it. You can build a cap with a check valve for the turbo-side of your charge pipe, and pressurize it with an air compressor. Its not perfect, but you can sometimes hear tiny leaks if your lucky.
Old Apr 4, 2005 | 10:25 PM
Evo-man@20psi's Avatar
Check your boost gauge
Old Apr 5, 2005 | 04:40 AM
nzrnk's Avatar
Default Re: Boost leak? (Blue00vtecsi)
When I look at the boost gauge it will hit max boost then drop back down as soon as let off the accelerator, is that normal or is that a sign of a boost leak.
ragethemachine86
Sep 12, 2006 07:58 PM
dan_w_82
Mar 28, 2006 11:37 AM
turbonitrousgsr
Oct 6, 2003 06:54 AM
genop
Mar 31, 2003 06:04 PM
CRVRX
Nov 16, 2002 08:03 PM
