Turbo Problems
Old Mar 11, 2006 | 12:45 PM
BigAnold's Avatar
Default Turbo Problems
OK well I figured since I belong to this board and you guys are very helpful I'd check here first. I bought a 1988 Dodge Daytona Turbo and today started having problems with it. There was a problem in my vacuum lines and it would not fully boost. Once I fixed it, and yes I fixed it right, the turbo wouldn't spin and when the throttle was opened the line from the throttle body to turbo would collapse (Non-intercooled car). So I did what would be normal and replaced it. Now the tubing won't collapse but still no spool. I wanted to see what might be causing this before I go ahead and tear it apart since the exhaust and intake manifolds are both on the rear of the motor meaning I would have to take both off to inspect. In case you were wondering about the vacuum problem it was just a line that was disconnected under max boost. thanks ahead of time
Maple50175
Jul 27, 2008 04:07 PM
postman
Apr 24, 2008 02:41 PM
kampucheakid
Apr 17, 2006 11:10 PM
93NTEGLS
Jul 1, 2005 09:14 PM
WEPN R
Jun 12, 2002 12:02 PM
