turbo coolent feed and return
Old Jun 12, 2002 | 12:34 AM
WEPN R's Avatar
Default turbo coolent feed and return
hi there,
Ive got a JDM Civic EG9 running B16A2 engine and i wana turbo it, Im will be running a TD05H turbo and just wondering if anybody can help me by locating a feed and return line for coolent for the turbo core.
How good will this turbo run on a B16A2 will it be laggy and when will it be on full boost.
All replies would be appreciated.
I know were to connect the coolent lines on the turbo,but I mean from wat source can I get the coolent to feed the turbo core, and what source to suck the coolent from the core.
Hope this clarifies the question.
thanks
Steven
[Modified by WEPN R, 9:52 AM 6/12/2002]
Old Jun 12, 2002 | 12:43 AM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: turbo coolent feed and return (WEPN R)
You probably wont have any lag and the coolant ports are on oppisite sides of the turbo.
art
Old Jun 12, 2002 | 01:08 AM
inspyral's Avatar
Default Re: turbo coolent feed and return (Arturbo)
run it in series with your throttle body/IACV heater line, or tee off your heater core line and run it parallel.
Old Jun 12, 2002 | 03:05 AM
civictypenos's Avatar
since most people like to bypass the water lines that run through the throttle body,the ones that heat up your throttle body,i use those lines,just pull both of them off and get some adaptors to extend the hoses to the turbo.
Old Jun 12, 2002 | 03:33 AM
ninesecrx's Avatar
Just dont run the coolant lines at all.
Old Jun 12, 2002 | 06:51 AM
GruvyTune's Avatar
New User
Default Re: turbo coolent feed and return (inspyral)
I agree, run off Tees to your heater core in and out lines. parallel your turbo to your heater core. that way no idling problems with involving your TB.
I suggest getting Earles/Aeroquip fittings to make a right angle hose barb fitting off your turbo inlet and outlet and run either stainless braided lines or get Aeroquip socketless hose and firejacket (thats what I'm doing). I used regular heater hose on straight fittings and had a slight kink and the heat made my line blow and lost all my coolant and overheated my car! Gonna do it better 2nd time around if I ever get my backordered hose.
If you got a wet housing turbo use it, your turbo will last longer!
Old Jun 12, 2002 | 12:02 PM
Islander's Avatar
New User
Default Re: turbo coolent feed and return (GruvyTune)
Pics would be very nice.
EJ8Squad919
Oct 19, 2012 03:57 PM
PINKS
Feb 22, 2007 03:51 PM
ek_99_SiR
Jul 2, 2004 07:14 PM
Accord94DX
Apr 27, 2003 12:31 PM
SilverLudeSi
Jan 29, 2002 06:20 PM
