Turbo Pre-install & Install Checklist - Critics Welcome
Help me out if there is anything I have missed:
Install order
-Make sure car is running properly before beginning install
no codes
no weird sounds
no fluids leaking
compression test
leak down test
valve adjustment, clearance check
oil filter/fluid change
tranny fluid change (overkill, but you still may need one)
no bolts or screws missing
inspection is up-to-date J
-Wire in and install new high volume fuel pump with upgraded wire and relay
-Wire in LM-1 - WB 02, cut stock wires and mate up with analog out on unit
-Chip, burn the BIN file and install ECU
-Take off stock exhaust manifold
-Bolt up turbo manifold
-Bolt Turbo to manifold
-Bolt Wastegate to manifold
-Bolt Downpipe to turbo
-Drain Oil and drop oil pan
-Install pre-tapped oil pan with new stock gasket
-Install LM-1 WB into downpipe
-Connect wiring and zip tie excess
-T off oil fitting from back of the block
-Install oil feed line from block to turbo
-Install oil return line from turbo to oil pan
-Fill engine with oil
-Install injectors (seals should be ready to plug and play)
-Check all clearances at this point
-Should be able to start the car and let idle, tune and rechip if idle is sketchy, no codes if 02 is operating correctly
-Install Vacuum and Boost silicone tubing
Wastegate from Turbo or charge pipe before intake manifold (better)
Run a line for vacuum to BOV
-Install Catch Can
-Take off front bumper and mount FMIC
-Trim excess front bumper for fitment
-Take measurements and cut charge pipes to diagram
-Install charge pipes (to best of ability)
-Install Air Filter
-Check Coolant Level, color
-Drive to Meineke and get exhaust, charge pipes, and extra bung welded
-Drive home carefully
-Check everything
Oil lines
Vacuum Lines
Charge Pipe Clamps
No loose bolts
Oil Levels
Coolant Levels
-Drive like hell everywhere else
-Install E-cutout when all is operational
-Tune Tune Tune Tune Tune
Modified by xenocron at 11:34 PM 9/30/2003
Modified by xenocron at 11:59 PM 9/30/2003
Install order
no codes
no weird sounds
no fluids leaking
compression test
leak down test
-Install Catch Can
-Install Air Filter
-Check everything
Oil lines
Vacuum Lines
Charge Pipe Clamps
No loose bolts
Oil Levels
Coolant Levels
Re: Turbo Pre-install & Install Checklist - Critics Welcome (xenocron)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xenocron »</TD></TR><TR><TD CLASS="quote">-Should be able to start the car and let idle, tune and rechip if idle is sketchy, no codes if 02 is operating correctly
Modified by xenocron at 11:34 PM 9/30/2003</TD></TR></TABLE>
EEK! Idle before Oil = no!
-Install pre-tapped oil pan with new stock gasket</TD></TR></TABLE>
it might be kinda hard to take off the oil pan w/ a downpipe in the way... just a thought
Re: Turbo Pre-install & Install Checklist - Critics Welcome (90civichbsi)
I make those lists too! Idk if it's just me but i usually NEVER end up lookin at it.
After I write it, im too lazy to read it lol. Im in a "go like hell" mood.
But i'd also retard the timing a couple degrees too when your done just to be on the safe side
Re: (bigwig)
sure...but i have to finish mine and make sure i have some spare time...life is nuts and the girlfriend needs attention...oh ****, forgot to put that in the list
*add, give girl some luvin - some where in the middle
Re: (ricodemus)
Yes bolt the turbo to manifold before mouting. Also a hint that weill save some time and headache. Right before you mount the turbo/manifold have a friend tighten the feed line to the flange, Prior to mounting. Trsut me its easier then doing it once it's on . To prevent exhuast leaks is use studs, lock washers,loctite and tighten well. Take your time and don't rush.
Re: (ricodemus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ricodemus »</TD></TR><TR><TD CLASS="quote">You also may want to bolt the turbo to the manifold first before it goes on the car. those bolts are sometimes hard to get to.</TD></TR></TABLE>
You mean like this?
Yeah forgot about the timing, i already have that set on mine...
I do have to get the spark plugs tho...hmm
You mean like this?
take your car in stock form to a muffler shop and get your welding done. take it off and take it home >>> now you have all the welding and parts right there to just bolt on! >>> no worries about driving in boost and blah blah blah and especially cops >>> tune tune tune before you drive like hell everywhere else
Re: Turbo Pre-install & Install Checklist - Critics Welcome (mamaboy)
for me, the problem is im running different flanges, a flex pipe, a cutout pipe and then the 2.5" Cat and back.
i dont think i could get all that welded correctly to bolt right up to the downpipe...i could be wrong...i just them to do it correctly without having everything all there
the pre-install oil change seems a little over the top to me. Why change the oil if you're going to have to drop the whole pan soon??
Re: Turbo Pre-install & Install Checklist - Critics Welcome (Ricey McRicerton)
Mainly for the new oil filter...
You can re-use the new oil in the oil pan but it's $20 for 4 quarts right?
Re: (bigwig)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigwig »</TD></TR><TR><TD CLASS="quote">ill **** your g/f while you turbo my car</TD></TR></TABLE>
haha.
haha.
Guest
Posts: n/a
Re: (xenocron)
You mean like this?
I do have to get the spark plugs tho...hmm</TD></TR></TABLE>
where can i get one of these turbo LAZ-Boys at?
You mean like this?
i ♥ my honda
Global Mod
Global Mod
Re: (xenocron)
You mean like this?
I was wondering of any advantegs of mounting the wg like that? I have a new black 38mm tial and I think I am just going to bolt it sttaight on w/o that elbow. Would this cause a prob? I am 98% shure its not going to come that close to the hood. Thanks....
PS.. Is that an inline pro mani??
You mean like this?
Re: (si2die4)
Ive been told that i need an elbow with my car...if I end up not needing it, ill ditch it. No specific advantages
Yes, it is an inline pro.
J1A1H
07-06-2006 07:06 AM
technine
05-27-2003 03:23 PM
