turbo oil drain parallel with ground?
Old Nov 7, 2002 | 05:52 AM
1tyme's Avatar
Default turbo oil drain parallel with ground?
my drain isn't facing down but it is parallel with the ground. will it still drain as long as i put the oil pan fitting lower than it?
Old Nov 7, 2002 | 06:01 AM
SJP0tato's Avatar
Default Re: turbo oil drain parallel with ground? (1tyme)
Do you mean the drain connection right out of the turbo? If so, then no it will not work. Corky Bell mentions this drain must be within something like 30 degrees to perpendicular to the ground. In otherwords, as humanly close to straight down as possible.
Sorry if this isn't what you're talking about,
Ryan P.
ITS_Dunn
Mar 16, 2006 04:51 AM
TEG777
Aug 18, 2005 09:38 PM
Project99EK
Dec 29, 2004 03:32 PM
inline976
Nov 18, 2002 09:28 PM
willyboyK20
Nov 4, 2002 05:56 PM
