drain from turbo too low???
Old Nov 18, 2002 | 07:07 PM
inline976's Avatar
Default drain from turbo too low???
if you have a drain from the turbo to the oil pan too low can that cause any problems? i was told that i will blow my turbo if it is lower then the oil that sits in the pan.
Old Nov 18, 2002 | 07:15 PM
brian b's Avatar
New User
Default Re: drain from turbo too low??? (inline976)
if you punch it all of the oil goes to the back of the pan anyway dont put it in the bottom or anything, but if its about half at the level your still pretty much ok..
Old Nov 18, 2002 | 08:08 PM
Full-Race Javier's Avatar
Default Re: drain from turbo too low??? (brian b)
drain is gravity fed, make its path as easy as possible
Old Nov 18, 2002 | 09:28 PM
First Gen Man's Avatar
Well.... I think ..just put the new turbo on.. and then ran a "hella" clean drain line to the new bung
justYncredible
Feb 8, 2012 10:20 AM
Vp Special K
Jul 25, 2005 06:15 PM
s2kkid
Nov 27, 2004 04:10 PM
dunkd
Mar 8, 2004 09:07 PM
willyboyK20
Nov 4, 2002 05:56 PM
