turbo not spinning
Old Dec 2, 2001 | 06:52 PM
threatcon13's Avatar
New User
Default turbo not spinning
we just finished setting up the drag 3 on my car...after everything was done we started up the car, the turbo seemed to be spinning very slow, afterwards we revved it up via throttle rotor, the turbo started spinning quickly. next time we started it up, the turbo wasnt spinning at all. we shut down the car and tried to move the blades by hand, they were stuck! wouldnt budge at all. my friend thinks the cartridge might be misaligned(didnt kno what he was talkin about) and he could fix it ...or if it wasnt that the turbo is defective. what do u guys think? we checked the oil feed and oil return lines and oil is getting through..so please help. thanks.
Old Dec 2, 2001 | 06:54 PM
Damon B.'s Avatar
Default Re: turbo not spinning (turbo01gsr)
Did you prep the oil feed line before setting it up to the turbo? (did you crank the motor until oil came out first?)
Old Dec 2, 2001 | 06:58 PM
New User
Default Re: turbo not spinning (CleanSi)
nope..we didnt do that just drained the oil...
Old Dec 2, 2001 | 07:40 PM
Damon B.'s Avatar
What do you mean by "just drained the oil"?
Old Dec 2, 2001 | 07:42 PM
New User
i was just watching and learning ..helping my friend here and there... i dont recall him doing what u were talkin about ..i just remember when we drained the oil..thats all...if we didnt do that, what should i do?
Old Dec 2, 2001 | 08:48 PM
Damon B.'s Avatar
when you say drain, I'm thinking out of the bottom of the oil pan, is that what you mean? What I'm talking about has t do with the steel braided line that connects to the oil pressure sending unit on the back of the block. You crank the motor until oil comes out of the steel braided line on the open end, then you connect it to the turbo, did you do that?
Old Dec 2, 2001 | 08:53 PM
New User
yes we did do that.
Old Dec 2, 2001 | 08:58 PM
captain4g63's Avatar
if you havent run the car yet, it shouldn't have frozen due to the oil. I'd bet something fell into the exhaust housing, i.e. a nut or bolt. Unless its used, then you may never know for sure.
[Modified by captain4g63, 10:24 PM 12/2/2001]
Old Dec 3, 2001 | 12:40 AM
liam821's Avatar
25 Year Member
Default Re: turbo not spinning (captain4g63)
agree...i bet something fell in too....running for only a short time like that without oil isnt going to hurt it.
liam
bubbleboy22
Jun 18, 2007 03:26 PM
hold your breath
Feb 14, 2007 10:01 AM
nicktagz
Sep 10, 2006 07:38 PM
O16581724 5 2 5
Nov 24, 2005 09:29 PM
EJ1 wilcox
Feb 5, 2005 05:30 PM
