is there a gasket between the WG and manifold ?
Re: is there a gasket between the WG and manifold ? (97CivicFerio)
this is between the WG flange and mani i assume ? what about between the WG and the flange ?....i dont even know how those two connect together.
where can i get this wg->mani gasket ?
Re: is there a gasket between the WG and manifold ? (D-SPEED)
Think you need the fire ring gasket.
http://www.turboneticsinc.com/catalog/wastegate.html
Re: is there a gasket between the WG and manifold ? (GSR_Dude)
I don;t have any, just make sure you botj surfaces are flat and clean, tighten it up, in a day or so, the carbon will seals up all the pinhole leaks....
I burned out two gasket already....
Yeah, the ones that come with the Tial wastegate are pretty crappy. Burnt them out in no time.
liam
Re: is there a gasket between the WG and manifold ? (liam821)
my gasket broke too quick
all ya gotta do is run a lil rich for a bit and build up a carbon seal....
also.... its a tight seal w/o it
IloveNewt
01-21-2004 06:20 PM
SpeedMonkeyRacing
10-09-2003 12:33 PM
