turbo not spinning
Old 06-26-2004, 05:09 PM
MNsnowdaboy's Avatar
Default turbo not spinning
like it says, my turbo doesnt spin even at idle. Thought it was the turbo bought an new one and same scenerio. Car would start and idle fine, but the turbo is not moving. Could it be te valves are loose and cause it not to spin? compression and everything is fine. Need some expertise help. Any thoughts turbo folks......
Old 06-26-2004, 08:30 PM
project dc2's Avatar
Default Re: turbo not spinning (MNsnowdaboy)
need to nkow your set up first. what motor. turbo. manifold set up. not all turbos will spin at idle. i know on my integra it didnt sometimes esp in the beginnin.
Old 06-26-2004, 10:18 PM
rusteds2k's Avatar
Default Re: turbo not spinning (project dc2)
My integra with a t3/4oe don't spin at idle sometimes also.
Old 06-26-2004, 10:41 PM
SBCCIVIC's Avatar
Default Re: turbo not spinning (xaznxboixsirx)
rev the mtor and see if it spins. my t3/t4 didnt on my h22 but my t-66 does, cuz it has ceramic ball bearings.
compton
Old 06-27-2004, 03:50 AM
svmnredracr's Avatar
i know my motor been racing ...b18c big bore, eagle rods, je pistons, blah, blah.. jg head rev hard front facing mani. t67 turbo...drag motor.etc..... I know that its not the turbo,, thats why this was posted, all the turbo that i slapped on this motor is reacting the same way. I was running an t72 dual ball bearing b4 and that thing spun until something happened and all the turbo i have now wouldnt spin
Old 06-27-2004, 04:09 AM
H-T White Ops
Frozen E's Avatar
DejaVu anyone?
https://honda-tech.com/zerothread?id=907592
Old 06-27-2004, 04:52 AM
Default Re: turbo not spinning (H22 TURBO'D HATCH)
c'mon wheres all the turbo heads at, I've already tried everything that everyone has thought of, I or may I say we need some more info... its probably one of those heads slappers when its all said and done.???? HELP HELP!
Old 06-27-2004, 08:32 AM
Chris F's Avatar
Default Re: turbo not spinning (svmnredracr)
Are you posting under two names? You're not the one that made the first post on the thread svmn.
Maybe you put the turbo on backwards (intake or exhaust). Or you have 2 busted turbos.
Old 06-27-2004, 08:35 AM
Killa's Avatar
Default Re: turbo not spinning (ccfries)
1) you might have too big of an exhaust side for that motor making it hard for the turbo to spin at idle but fine under load.
2)broke turbo
3) There can't be any closed valves because if your valves were closed then your car wouldn't run
hth
Paul
Old 06-27-2004, 10:28 AM
LoSt is BlaCk's Avatar
Location: Just Drank A 5th of VODKA Dare me to drive, Ca, u.s.
Default Re: turbo not spinning (Killa)
what condition is your mani in? do you have any vac. leaks? have you tried revving it to see if it spins, will it spin under load? when driving are you seeing any boost?
Old 06-28-2004, 04:41 AM
posted it while my cousin was on but yeah its all me
Pellegrini808
09-30-2013 03:56 PM
turboman2.2
04-30-2010 07:05 AM
mnlude
04-12-2006 04:54 PM
tranceologist
09-17-2005 12:58 AM
TurbothisLS
10-08-2002 08:29 PM
Quick Reply: turbo not spinning
