turbo with no intercooler or bov
#26
Good, Bad…I'm the one with the gun
Location: Trapped in time, Surrounded by evil, Low on gas
1 Post
Re: turbo with no intercooler or bov
i want to add, that the L28ET that had the turbo feed into intake manifold right away has solid block deck, rods that can take 800+hp and dished pistons. those are engines that can withstand detonation and keep ticking.
#27
1 Post
#28
Moderator
i am sorry again man, but you are confusing it with the 300ZX. i have this engine laying around now, and i can assure you, the turbo outlet went directly into the intake manifold. the part is called a j-pipe for a reason. the pop-off valve didn't actually let off boost off throttle, it couldn't as it was located on the intake manifold and only worked during over boost situations, we used to weld them shut back in the day.
And I hated the 300ZX, so I know the difference in engine platforms.
#31
Moderator
Sorry OP, we'll get back on your topic after this little diddy here.
#32
1 Post
the L28ET came in the 81-83 280ZXT. none of them were intercooled. i was a Datsun head long before i began dabbling in Honda (used to hate them, actually). my first car was a 83 280ZXT (miss it dearly).
here is another shot of a stock L28ET. you can clearly see the j-pipe connecting the turbo outlet to the throttle body and the pop-off valve on the intake manifold to the right (the mushroom looking thing)
#33
Moderator
Then I concede.. the ones that I had were aftermarket installed after the fact from the sources available then. But even you would have to agree, that the use of the intercooler would have made a world of difference in this case.
But even you must concede to the purpose of the pop-off valve that they are using in the L28 and L20 models was to avert reversion similar to a modern day "blow off valve".. Now that I am correct on.
#34
1 Post
you bring a torrent of information here, and i would never try to undermine it. i agree that running without an intercooler on a honda engine is a silly thing (those engines are fragile) considering the low cost of the components.
installing an intercooler was the first thing we did, usually it was off the Isuzu NPR truck.
#35
Who is Mr Robot?
Considering most people with real intercoolers only see temps 10-30 over ambient....:-) whoever you're listening to is an idiot.
If the turbo is designed for it, you can get away with no bov or if its a race only vehicle... your setup ,cost likely wont be up to those standards
#36
For 6 psi, why not just get a 1g DSM valve? I got mine for $20 shipped, cheap insurance for your turbo and oem function and longevity.
#37
#38
You dont have to have an intercooler. A bov however is a good idea to save the compressor. If you dont use an intercooler the car is going to get heatsoaked very quick and then take forever to cool back off. Water/meth can serve as an intercooler.
#39
Moderator
#40
i'm deciding that i'm going to run a DSM side mount intercooler and probably a DSM blow off valve.
while it seems possible to not use an intercooler, i'm concerned about hot days or getting a bad tank of gas and blowing the motor.
the rx7 guys in the thread i posted make me want to experiment with not running a blow off valve but for the cost of a DSM BOV it would be nice insurance to have.
thank you all for the help in this thread.
#41
Who is Mr Robot?
At your low pressure levels it might not damage anything (quickly) but it will cause more lag between shifts.
But like you said, for that low of a cost its good insurance, glad to see you decided to go the safer route
Good luck with your build
#42
It sounds like your Trying to hide your running F/I? The Answer to your Question is Simple YES IC/BOV ARE RECOMMENDED I suppose you could Alleviate your IAT some by running Ethanol. Then just get one of them, Stupid Piece of **** Adjustable Ebay BOV's, set it as loose as possible then you will only hear a faint Puff Sound.
#43
Who is Mr Robot?
Tony the tiger ran his charge pipes through the stock air box and intake elbow.. he hid everything so well you couldn't tell even if he popped the hood, I'll try to find the thread
#44
Win haha... If I was going with such a Cheesie Boost Setup i'd wan2 hide it to lol... There is nothing more "Fabulous" then a Sneezing Rice Burner...
#45
i'm not trying to hide anything... i guess you could call the car a sleeper but i don't really care either way.
i'm only turboing because i want a little more midrange torque... i even plan on keeping the stock exhaust if that gives you an idea of how little i care about numbers or racing the car.
#46
#47
Moderator
If its about midrange torque and use, please use an intercooler and BOV (even if its a 1G DSM) and use a slightly larger exhaust to get the most out of your lower efforts to gain torque.
#48
