Turbo mounting question
Old Oct 9, 2002 | 07:30 PM
blufke's Avatar
Default Turbo mounting question
im wondering how i should mount my turbo. should the compressor be on the left side or right side(if you are standing looking at the engine bay from the front of the car). does this effect in any way the oil feed and return lines? i need to order my dp and need to pic a side. here are pics of the turbo im getting too. its a small t3/t4.
http://members.aol.com/iateyourcivic...e/turbo_01.jpg
http://members.aol.com/iateyourcivic...e/turbo_02.jpg
http://members.aol.com/iateyourcivic...e/turbo_03.jpg
thanks.
Old Oct 9, 2002 | 07:42 PM
89 CRX SI's Avatar
Default Re: Turbo mounting question (blufke)
neither like this.
Hope homemmadeturbo.com dont mind but its so sexy......
Old Oct 9, 2002 | 07:57 PM
blufke's Avatar
Default Re: Turbo mounting question (89 CRX SI)
yeah. already have my maxrev manifold though.
Old Oct 9, 2002 | 08:04 PM
DSC's Avatar
DSC
That thing actually works?
Damn.
Old Oct 9, 2002 | 08:09 PM
Quiz's Avatar
Mount it how ever you like. Make it as easy as possible to fit the down pipe to the exhaust and all the piping to intake manifold. after you figure that out loosen the bolts around the compressor and turbine and clock the center section so the oil feed is up and drain down. Clock the compressor housing for an easy fit.
Old Oct 9, 2002 | 08:20 PM
blufke's Avatar
Default Re: Turbo mounting question (Quiz)
you can adjust how the compressor and exhaust housings sit? didnt know that. im just curious though on what would be easier/cost effective/(any reason) on why to orient it a certain way. perhaps for ease of running fmic piping or whatever. tell me, thanks.
Old Oct 9, 2002 | 08:57 PM
89 CRX SI's Avatar
ok you casn only rotate the compressor housing and center section. you want your oil in and oil out to be vertical with oil drain out straight down. by turning the compressor side so it point downward amkes it easy to route IC piping. the filter then would sit behind the left front headlights. putting the turbo the other way would cause closer clearences between your filter and IC piping etc.
Old Oct 9, 2002 | 10:09 PM
blufke's Avatar
left front headlight i assume as seen from sitting in car. so the compressor being on the left side if sitting in the car as well.
Old Oct 9, 2002 | 10:20 PM
project dc2's Avatar
im wondering aboutt he homemade turbo set up above .. it sure looks nice but im wondering how the **** is he gonna do the charge pipes as well as the oil feed and return ?
Old Oct 10, 2002 | 12:10 AM
PreIudeSI's Avatar
From: California ... Beauuutiful, so cal, pwnited States
Default Re: Turbo mounting question (project dc2)
I'd love to get that setup, it'd be perfect for an air-liquid intercooler. I might look into it for my prelude, prolly have to sell a kidney to afford that mani though.
Old Oct 10, 2002 | 01:56 AM
blufke's Avatar
anyone?
Old Oct 10, 2002 | 05:26 AM
brcivic411's Avatar
no,
an easier way to think of it is the filter and compressor will be on the passenger side. the turbine will be on the drive side. there's no wrong or right way. which ever way fits best... but usually to run a FMIC, it's easiest to have it as above
Old Oct 10, 2002 | 07:18 AM
89 CRX SI's Avatar
Default Re: Turbo mounting question (brcivic411)
the homemade setup above will be using a air- liquid intercooler. Will have a very short section of charge pipe. the downpipe goes down and exits infront off passenger sie front tire
here is the down pipe
New intake manifold
just go to http://www.homemadeturbo.com and find build ZC/ Race ZC
Old Oct 10, 2002 | 11:13 AM
blufke's Avatar
no,
so its better to have the compressor on the passengers side. i thought that perhaps having the compressor closer to the drivers side to run the ic piping would be easier, but i dunno. set me straight on what i should do.
Old Oct 10, 2002 | 01:19 PM
PeakBoost's Avatar
B*A*N*N*E*D
there is a very similar post to this, that i just replied to.
we have some pictures of a customers honda on our website that you might want to take a look at. he ran his setup pretty cleanly with the compressor on the drivers side.
[Modified by CHEAPTURBOdotCOM, 10:20 PM 10/10/2002]
Old Oct 10, 2002 | 03:03 PM
blufke's Avatar
Default Re: Turbo mounting question (CHEAPTURBOdotCOM)
im really curious on benefits and reasons for each. either way im getting a custom dp made. so anything to do with running into the oil return line/fitting or filter placement or fmic piping would be helpful on how to mount it.
Old Oct 10, 2002 | 03:16 PM
TheIntegraGuy's Avatar
that's an amazing machine.
Old Oct 10, 2002 | 04:58 PM
blufke's Avatar
Default Re: Turbo mounting question (SiDESLiDE240)
uppity
Old Oct 10, 2002 | 06:11 PM
BudaKai's Avatar
I can see the benefits of the compressor on the pass. side without the fmic and an air - liquid. Quite true with it on the driver side with a fmic. If you move the turbo too far away from the exhaust pool you might experience more lag, however if your turbo set-up has that big of a snail the lag wouldn't mean dick when you finally got boost (I'm talking about the pic of course). Then you gotta find traction though.
Old Oct 10, 2002 | 07:05 PM
blufke's Avatar
Default Re: Turbo mounting question (tzsir)
so is going with the compressor on the passengers side not going to be a problem then? gonna order my custom dp soon.
Old Oct 10, 2002 | 08:45 PM
Dee's Avatar
Dee
Here's my choice!
JDMeg95
Nov 11, 2007 06:57 PM
94_del_sol
Oct 6, 2005 05:33 PM
pwerbnd
Aug 17, 2005 06:37 AM
89dxhunchback
Jan 19, 2004 10:36 AM
fastrex
Apr 4, 2002 09:22 PM
