Garrett turbo woes ...
Well I am exp. somthing I have not seen before ....so I thought I would ask , have any of you ever seen a garrett GT turbo , not let the oil drain through , the is a restricer ( to keep the pressure in check ) the drain is almost vertical but there is is no oil in the drain and there is burnt smeeling oil still in the top of the turbo ....even after I pull the restricer out and all ....I am confused , I have never seen this before , there is oil is not getting through , and the turbo **** this evening , after only driving a few hundred miles ( mayby 200 or so ) since friday when the car got running...any ideas
Re: Garrett turbo woes ...
I have a sleeved SR20VE ...the turbo was getting oil , but it there is no oil in the drain side of the turbo ....oil and pressure on the inlet side of the cartridge , none on the other so it cooked the oil in the turbo .....
The turbo was clocked corectly , and the drain had no kinks , the oil drain was dry inbside and lacked the horrible cooked oil smell
It was a GT35r ....I ordered a SC6262 this morning to it running again , I still want to know what happend though we have a few thoughts
EJ1 wilcox
02-05-2005 05:30 PM
