Turbo Manifold Temps
Old Nov 16, 2005 | 09:07 PM
IMPACT's Avatar
Default Turbo Manifold Temps
Hey guys, i have a drag turbo manifold. There is a temp sensor on the 3rd runner. When the motor was being built the tuner told me that i should have the temp sensor there. I also have another one on the downpipe. He told me i should watch the temp on the manifold, shouldnt go past 1500f. Why? Can anyone tell me? I want to be as cautious as possible..
Thanks
Old Nov 17, 2005 | 09:05 AM
DannyDeuce's Avatar
Default Re: Turbo Manifold Temps (IMPACT)
Well, it would be way too hot then...kidding.
Normal temps should be:
Cruising - 600-800 F
Highway and WOT - 1200-1400 F (I've hit 1500 F once or twice).
DAN
Old Nov 17, 2005 | 09:59 AM
Muckman's Avatar
Moderator in Chief
Why? - because you will cause internal engine damage when things get too hot. Metal deforms, expands, weakens or all of the above.
Old Nov 17, 2005 | 10:03 AM
BlueShadow's Avatar
http://www.sdsefi.com/techegt.htm
Old Nov 17, 2005 | 10:18 AM
dpetro1's Avatar
Default Re: Turbo Manifold Temps (BlueShadow)
^^^good article.
to the original poster. in case you havent figured it out yet. that temp sensor measures the temperature of the exhaust gases leaving the head (EGT), not the temerature of the manifold itself.
its hard to say that particular EGTs are safe or "normal". it really depends on the setup and could vary. EGT measurement is also determined by the placement of the probe. EGT will be much higher at the manifold than at the downpipe.
the article discusses nicely that higher EGT doesnt always mean a leaner mixture and that EGT shouldnt be the only parameter used for tuning.
jdmcrx_echelon
Apr 26, 2011 03:36 PM
b20beast83
Jan 30, 2009 01:05 PM
Hyaboosta
Feb 28, 2005 06:25 PM
01ITR#700
Jan 11, 2003 04:38 AM
