Manifold and turbo temps???
Old Apr 24, 2011 | 10:46 PM
jdmcrx_echelon's Avatar
Default Manifold and turbo temps???
Wondering what the temps for turbo manifolds and turbos get up to.
Its a inline pro log manifold and a garret turbo on a B16a running 13lbs if that info helps. Sorry if its a dumb question but couldnt find any solid numbers anywhere.
Old Apr 24, 2011 | 11:30 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: Manifold and turbo temps???
hard pulls manifolds can reach over 1,000F and start to glow. same for turbo's. I havent shot my infrared sensor at one, but thats the basic point at which steel/iron starts to glow, around 772-1099degrees
egt's can easily reach 1800F
Old Apr 25, 2011 | 10:33 AM
Well the reason i ask is because ive got a powdercoat setup and im wanting to high temp coat my manifold and possibly turbo. But the high temp powder says its good up to 1200 degrees.
Old Apr 25, 2011 | 08:53 PM
W!d3b0dYr3X's Avatar
It will look good for a while but most setups I have seen it usually comes off shortly after. Just from the extreme flucuations in temps. Going from 1200-1500 egt under full boost to 300-600 at idle is demanding on even powder coating
Old Apr 25, 2011 | 09:16 PM
$amGD3's Avatar
Swaggylicious
I believe there is a few different types of coating that you can do for your manifold that will withstand the heat range and even keep temperatures down a bit.
But a regular powder coating is highly discouraged to do on a manifold because it just wont endure the heat.
Old Apr 26, 2011 | 03:36 PM
Thanks for the input guys. Thats exactly what i was wondering
hybridmiklo
Sep 4, 2011 01:08 PM
s.cha
May 11, 2009 08:44 PM
all_motor_mike
Welding / Fabrication
Jun 5, 2006 01:06 AM
Wicked671
Mar 29, 2003 12:12 AM
94hondaLS
Feb 6, 2003 08:42 AM
